my gsr is bogging or studdering below 3k
Old Oct 5, 2003 | 08:32 PM
dc2inms's Avatar
Default my gsr is bogging or studdering below 3k
anyone know what this could be? it kinda studders sometimes, but only below 3k rpm. I changed the plugs and I am ordering some wires, cap, and rotor. Its not throwing a code either.
Old Oct 6, 2003 | 07:13 PM
dc2inms's Avatar
Default Re: my gsr is bogging or studdering below 3k (greenegbean)
anyone?
Old Oct 6, 2003 | 08:51 PM
artifex's Avatar
say it
how many miles are on it?
Old Oct 7, 2003 | 03:49 AM
dc2inms's Avatar
Default Re: my gsr is bogging or studdering below 3k (artifex)
85k
Old Oct 7, 2003 | 03:50 AM
ebelp's Avatar
After you get the wires, cap, and rotor on, let us know what happens.
Old Oct 7, 2003 | 09:00 AM
revhappy420's Avatar
Default Re: my gsr is bogging or studdering below 3k (ebelp)
check your distributor timing with a timing gun. sometimes, when the timing is off, it would make your car misfire or stutter like that. and if you haven't changed your fuel filter for 85k miles, now is the time to do it, they should be changed every 60k miles. could be clogged too, but i highly doubt it.
Old Oct 7, 2003 | 09:29 AM
Full Race EG's Avatar
Default Re: my gsr is bogging or studdering below 3k (revhappy420)
sounds like it just needs a tune up.
Old Oct 7, 2003 | 09:50 AM
cyphergs-r's Avatar
Default Re: my gsr is bogging or studdering below 3k (IntegraLStuner)
My car recently is doing the same thing. It is throwing misfire codes all the time and the CEL is always on, and there is a clicking noise coming from the engine that was never there before. The shitty part about everying is my car just started acting up when I got it tuned a month or so ago, never had a problem before that. Car has 70k.
Old Oct 7, 2003 | 10:07 AM
x00gsr's Avatar
I hope you atleast tried to change the idle before you ordered all those stuff.
Old Oct 7, 2003 | 12:35 PM
superthug's Avatar
Default Re: (x00gsr)
o2 sensor?
Old Oct 8, 2003 | 05:05 PM
drunknmonkee's Avatar
ur not in VTEC yet
Old Oct 8, 2003 | 05:07 PM
not ur clutch is it? becuz my clutch is slipping and it bogs at the lower rpms
Old Oct 8, 2003 | 06:19 PM
spd18's Avatar
do you have your A/C on? when i have my AC on, my car stutters when accelerating at/around 3k; it feels, and is slower all around in general with the AC on, but for some reason i feel a stutter at around 3k. i dunno why.
Old Oct 8, 2003 | 07:02 PM
hondaprince20's Avatar
also, check fuel filter and injectors, if you have a fuel pressure regulator fuel pressure might be too low. Air, Fuel, Spark..... gotta be one right. process of elimination.... let me know what happens.
Old Oct 8, 2003 | 07:12 PM
P1mpSlap's Avatar
bounce her off the revlimiter a couple times. That fixes anything.
Old Oct 8, 2003 | 07:24 PM
teg_b18c1's Avatar
I had that same problem last week . Tune it up. Also use the cheap NGK copper plugs their better that the factory platium plugs cheaper they only wear out faster.
Old Oct 8, 2003 | 10:09 PM
wall of tvs's Avatar
Default Re: (P1mpSlap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap &raquo;</TD></TR><TR><TD CLASS="quote">bounce her off the revlimiter a couple times. That fixes anything. </TD></TR></TABLE>
lol
Old Oct 9, 2003 | 01:22 AM
sinfulDB1's Avatar
Default Re: my gsr is bogging or studdering below 3k (teg_b18c1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg_b18c1 &raquo;</TD></TR><TR><TD CLASS="quote">I had that same problem last week . Tune it up. Also use the cheap NGK copper plugs their better that the factory platium plugs cheaper they only wear out faster.</TD></TR></TABLE>
me too same thing happened to me last week i bought the cheap ngk v-power plugs and she runs great now
Old Oct 9, 2003 | 01:33 AM
integraL's Avatar
Default Re: my gsr is bogging or studdering below 3k (cyphergs-r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cyphergs-r &raquo;</TD></TR><TR><TD CLASS="quote">My car recently is doing the same thing. It is throwing misfire codes all the time and the CEL is always on, and there is a clicking noise coming from the engine that was never there before. The shitty part about everying is my car just started acting up when I got it tuned a month or so ago, never had a problem before that. Car has 70k.</TD></TR></TABLE>
misfiring codes are usually just bad wires
beanbag
May 3, 2013 06:19 PM
sonny0330
Jun 3, 2008 02:52 PM
`chrisb
Apr 29, 2008 08:31 PM
fast94ex
Nov 30, 2004 07:56 PM
CzanSOHC
Mar 21, 2004 10:56 PM
