urethane bushings for short shifters
Old Oct 5, 2003 | 07:51 PM
IWearMyKswiss's Avatar
New User
Default urethane bushings for short shifters
where is the cheapest place to get them and whats the going rate for them nowadays?
Old Oct 5, 2003 | 07:56 PM
jdmsiR20's Avatar
Default Re: urethane bushings for short shifters (WiDeBoDyEK)
cheap! i think i seen it for $8 shipped... somebody else must know where...BUMP
Old Oct 5, 2003 | 08:01 PM
tzonni's Avatar
pep boys
Old Oct 5, 2003 | 08:33 PM
New User
but i want good bushings,...doesnt ES make bushings for the short shifters?,...anyone got links ?
Old Oct 5, 2003 | 08:55 PM
FifthGearOnline's Avatar
Default Re: (WiDeBoDyEK)
i got my bushings from neuspeed.....i lovem
30 bux isnt bad at all
Old Oct 5, 2003 | 08:57 PM
degooser's Avatar
try http://www.inlinefour.com
think i got mine shipped for under 20 bucks..
Old Oct 5, 2003 | 09:37 PM
MrIllegalX's Avatar
bushings for a short shifter gonna do much? make it smoother? I don't think I got new busings installed when I have my shifter installed.
Old Oct 5, 2003 | 09:49 PM
Viorent Grip! EG's Avatar
Default Re: (MrIllegalX)
best 8 bucks i've ever spent!
Old Oct 5, 2003 | 09:54 PM
RedDelSol si's Avatar
i highly recommend the enrgy suspension stabilizer bushings. i just recently instaleed them in my sol and the difference is night and day. the shifts feel alot more positive, the shifter feels tighter, its alot more solid when put into gear, ie no more play when youre in gear, and for 19 bucks with shipping from summit you cant go wrong IMO.
Old Oct 5, 2003 | 09:56 PM
MrIllegalX's Avatar
Default Re: (RedDelSol si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedDelSol si &raquo;</TD></TR><TR><TD CLASS="quote">i highly recommend the enrgy suspension stabilizer bushings. i just recently instaleed them in my sol and the difference is night and day. the shifts feel alot more positive, the shifter feels tighter, its alot more solid when put into gear, ie no more play when youre in gear, and for 19 bucks with shipping from summit you cant go wrong IMO. </TD></TR></TABLE>
did you install yourself? difficulty?
Old Oct 5, 2003 | 10:07 PM
i did instal it myself. it was easy except the bushings that are connected to the tranny will give you ****. they are a 2 piece bushing that you put a metal tube through. it was hard as hell to get in. i ended up using my vice and 2 small pieces of wood to press them in. this is for d series though. b series is super easy since that bushing is one piece. a tip for ya: i recommend that you unbolt the linkage from the shifter and remove the stabilizer bar with the shifter intact. just put the linkage of to the side and pull the other rod right out. it will be a lot easier to install them this way.
Old Oct 6, 2003 | 02:43 AM
AzntaggeR's Avatar
TSPeed Factory
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedDelSol si &raquo;</TD></TR><TR><TD CLASS="quote">i did instal it myself. it was easy except the bushings that are connected to the tranny will give you ****. they are a 2 piece bushing that you put a metal tube through. it was hard as hell to get in. i ended up using my vice and 2 small pieces of wood to press them in. </TD></TR></TABLE>
i feel ya
it should've tooken me about 30 minutes tops to do this job, but it ended up taking me 2 hours just trying to force that bushing into the stabilizer bar. so finally i just took a razor and trimmed the edges and lubed the hell out of it so it would slide in.
conclusion - it was soo worth the $30 i spent ( ) and headaches of puttin it in. my shifts feel so crisp in every gear now.
Old Oct 6, 2003 | 03:31 AM
hondasport2000's Avatar
yea its an easy install, i just did it the other week....make sure u disconnect the shift linkages, etc and should be pretty straight forward.
Old Oct 6, 2003 | 03:35 AM
deeksmooth's Avatar
Default Re: (AzntaggeR)
Wouldn't using a razor almost defeat the purpose of the bushing? Just a guess.
Pep Boys stocks ES bushings, and normally has Honda Shift Linkage bushings in.
Old Oct 6, 2003 | 04:35 AM
JICEK9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrIllegalX &raquo;</TD></TR><TR><TD CLASS="quote">
did you install yourself? difficulty?</TD></TR></TABLE>
it's easier then doing a short shifter EASY
Old Oct 6, 2003 | 04:48 AM
MrDX's Avatar
Default Re: (JICEK9)
Like everyone is saying... Pepboys $14.99
Old Oct 6, 2003 | 04:53 AM
phantom_sol's Avatar
lol, i just did my bushings last friday. i used the same method that reddelsol si used.
its a bitch putting them in by hand so i went ahead and used a vice and it poped in with a little persuading of a small flathead screwdriver, also getting it back ontot he tranny was a pain for me cause it didnt want to align with the bolt holes and the bushings started to expand, so adjusting was hard. as far as shifter feel, wow, it basically *pops* itself into gear, theres a little more resistance but definately more precise and less play. and del sol shifters have a fairle small throw to begin with so thats always a plus
the lubricant is like an adhesive though very sticky
Old Oct 8, 2003 | 02:02 PM
Caveman74's Avatar
Default Re: (phantom_sol)
Just bought Neuspeed bushings from NOPI.com for 11.19
Old Oct 10, 2003 | 12:00 AM
MrIllegalX's Avatar
what tools are required to do this?
Old Oct 10, 2003 | 04:36 AM
kommon_sense's Avatar
You can do this with hand tools. Jack the car up, have a wratchet with a 12mm and extension (to get bushing under shifter) and a 12mm wrench to get the bushings at the tranny. I didn't have a problem getting the new bushings in at the tranny and the metal tube slid right in. However I did have a lot of trouble lining the bushings back up to mount back into the tranny. You have to line them up to get the screw back in to hold everythign in place. I used the ES bushings.
I did this while installing a new exhaust, so it was pretty easy without a resonator in the way
Old Oct 10, 2003 | 05:20 AM
TABIAS's Avatar
I want to be MADE into Ice-T
Default Re: urethane bushings for short shifters (jdmsiR20)
inlinefour.com it was like 18.00 shipped not a bad deal and i got em in like 3 days
good luck
Old Oct 10, 2003 | 05:36 AM
DCStreetHtch's Avatar
Default Re: urethane bushings for short shifters (preacherboy)
13 bucks from Dynamic Autosports, 18.00 shipped isn't bad
-Bryan-
Old Oct 10, 2003 | 06:07 AM
Default Re: urethane bushings for short shifters (EGStreetHtch)
ebay 15 shipped
Old Oct 15, 2003 | 11:18 PM
MrIllegalX's Avatar
Opt AutoSalon has Energy Bushings for $9. what you guys think? a little too cheap?
Old Oct 15, 2003 | 11:47 PM
Tad's Avatar
Tad
tip,
get the hardest bushings you can.
although.. I dont know how your going to tell which is harder without having them side by side.
but yeah, sould make shifting feel less "gummy" and click into place.
