Cruise Control light is out (button) 6th Gen.
On my '99 Accord LX, the light for the cruise control button is out. You know, the button to the left of the steering wheel that turns cruise control on or off, the little green light in it.
Is this hard to fix? Where can I buy a new bulb?
it should be lite by a one of those mini-blub
you can pop out the switch from the fuse panel, just open the fuse panel on the driver side and you'll see how.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heat »</TD></TR><TR><TD CLASS="quote">
Is this hard to fix? </TD></TR></TABLE>
If your cruise still works, it's probably just the bulb. If your cruise doesn't work, check your fuses.
My 7th Gen Sunroof switch light is out. I think Im going to take the bulb out of the SI Cluster I have. Its been sitting in my garage since 2003. LOL!
I never did replace it, I decided that I preferred not having that green light on when the cruise control button is pushed in (which is most of the time that I'm on the interstate).
lol. I do not really turn mine off. I switched the illumination light for the green light, but I might switch it back. I need to get a few of those bulbs. My defroster light is out as well.
