Too late to switch to synthetic??
Old Aug 28, 2001 | 12:23 PM
Zulu888's Avatar
Default Too late to switch to synthetic??
I have about 70K kms on my car now and want to switch to synthetic, is it a good idea??
thanx.
Old Aug 28, 2001 | 12:32 PM
DavidGSR's Avatar
Default Re: Too late to switch to synthetic?? (Zulu888)
I switched my prior car (a Mazda 626) at about 50K miles and didn't have any problems. The only concern is that you may see some oil leakage. If it is severe you can either repair the leaking area or switch back.
Old Aug 28, 2001 | 12:51 PM
Mike95lude's Avatar
I switched at 70k...don't seem to be having probs. Go for it.
Old Aug 28, 2001 | 01:07 PM
itr0032's Avatar
Default Re: Too late to switch to synthetic?? (Mike95lude)
It's never too late
Old Aug 28, 2001 | 04:42 PM
mercury's Avatar
New User
For us metrically-challenged, 70000 kilometers = 43495.98 miles.
That's really, really low mileage for a '94! I wouldn't worry about switching to synthetic.
Old Aug 28, 2001 | 09:53 PM
Zulu888's Avatar
Default Re: Too late to switch to synthetic?? (mercury)
k, thanx, its the first thing i'm gonna do
Old Aug 28, 2001 | 10:03 PM
ZJ Nizzle's Avatar
New User
I switched at 137,000K miles with my Jeep.
I really don't think it's ever too late to switch.
Old Aug 29, 2001 | 07:08 AM
Mikes94's Avatar
Hey Zulu888,
I've got a '94 VTEC too. I purchased it second hand about 6months ago ... it had 80,000kms. At my first oil change I switched to Mobil 1 synthetic (it had previouly used Honda stuff). I've noticed that I seem to lose a little bit of oil every month or so (probably drops to 3/4 on the dip stick) and I just top it up. Not sure where its going ..have noticed a little oil under the car occasionally (but not much) so I assume I'm probably burning a bit. The car runs fine though and I'll continue to use Mobil 1 (and check the level regularly!!)
Mike
Old Aug 29, 2001 | 10:49 AM
BilLYgUNz's Avatar
New User
Default Re: Too late to switch to synthetic?? (Mikes94)
i switched about a month ago on my 94 gsr with 70,000 miles and it hasnt moved on the dipstick at all.
Old Aug 29, 2001 | 05:25 PM
uncleben's Avatar
I just switched to Mobile 1 at 99,500 miles on my '95 Teg. Haven't noticed any leaks or other odd things yet... I had already noticed it losing a slight bit of oil before oil changes quite a while back though. Now, guess I'm going to have to start doing the change myself now that it costs me almost twice as much with Mobile 1
[Modified by uncleben, 2:26 AM 8/30/2001]
Old Aug 29, 2001 | 05:54 PM
Mr. Choi's Avatar
New User
changing from conventional to synthetic oil isnt bad at all, even at a high mileage engine. you should beware of leaking seals after you switch to synthetic since synthetic oils has different additives and usually does more harm to the rubber seals in the engine compred to conventional oils, but theres only a slight chance of that happening so go for it.
Old Aug 29, 2001 | 06:06 PM
gsr camel's Avatar
I had a leak around my head and switched to synthetic at 90K miles and surprisingly the leak quit?!?! dunno if it was the oil or not?!?
Old Aug 29, 2001 | 07:31 PM
dc24me's Avatar
I started at 171,724 kms. Better late than never....
gsrsol84mm
Sep 19, 2006 10:52 AM
quazar
11
Oct 22, 2004 06:38 AM
itrsport.com
Nov 10, 2003 10:52 PM
Comptech98GSR
Feb 8, 2003 02:39 PM
HX_Guy
Jan 31, 2002 09:01 AM
