Will I get big gains in my B16 from ITR cams?
Old Oct 5, 2003 | 12:34 PM
Hatchbslo's Avatar
Default Will I get big gains in my B16 from ITR cams?
I did a search, and I didn't really find what I was looking for as an answer. I've looked on sites like http://www.importreview.com. and still no luck. I know that if I do change the cams its best to change the valve springs retainers ect.
Has anyone here done this mod? what HP gains am I looking at? is it worth my while to do?
thanks
Old Oct 5, 2003 | 01:06 PM
visi0n's Avatar
it will feel good, but will still feel stockish since they are stock cams. I hear its a good 5whp but i can't confirm this.
Old Oct 5, 2003 | 04:29 PM
TimoneX's Avatar
New User
Default Re: Will I get big gains in my B16 from ITR cams? (Hatchbslo)
You'll see primarily mid range gains. You'll want something to move your x-over point as well.
Old Oct 5, 2003 | 08:31 PM
GOLDBERG's Avatar
Default Re: Will I get big gains in my B16 from ITR cams? (TimoneX)
wow only 5whp?
Old Oct 13, 2003 | 09:57 AM
B16CRXT's Avatar
Default Re: (visi0n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by visi0n &raquo;</TD></TR><TR><TD CLASS="quote">it will feel good, but will still feel stockish since they are stock cams. I hear its a good 5whp but i can't confirm this.</TD></TR></TABLE>
DAmn that sux. I was planning to do the same thing to my b16 in hopes that it would give me like 15 extra hp. what do you think about crower and Skunk2 cams?
Old Oct 13, 2003 | 10:30 AM
-KangaRod-'s Avatar
It'll be more than 5 hp. Probably more like 7 or 8 hp. You wont need to change your valve springs as long as you keep your stock rev limit. Its a worthy gain.
Old Oct 13, 2003 | 12:38 PM
1999all_motoR_teg's Avatar
Default Re: (-KangaRod-)
With CTR cams I gained 14whp with minor tuning on a JDM 2nd gen B16A. I guess the mods on the engine make a difference so here's my setup.
JDM B16a SIRII
2000 ITR tranny
Skunk2 ECU
Brullen Catback Exhaust
RS*R header
custom shortram intake
CTR cams
ITR valvetrain
AEM cam gears(set at +5 intake and +1 exhaust)
The 14 whp was gained with only the CTR cams and ITR valvetrain added and since then I have added the RS*R header.
I am getting a VAFC by next season so that I can take it straight to the dyno to tune it better I'm hoping to squeeze about 2-3 more WHP out of it.
It's hard to tell what kind of power you will get from the cams but I am living proof that CTR cams can make relativley good gains and for SURE more then 5WHP.
Modified by CIVIC2 at 10:09 PM 10/13/2003
Old Dec 30, 2003 | 11:11 AM
Grandprix's Avatar
Default Re: (CIVIC2)
can you just throw ctr cams in a b16 or do you need to upgrade the valve springs?
Old Dec 30, 2003 | 11:14 AM
dc-lefty's Avatar
what's your hp #'s ??
Old Dec 30, 2003 | 11:27 AM
WAFFLES's Avatar
Default Re: (dc-lefty)
Gains will be dependant on other mods and tuning. The peak power gained from these cams, while nice, is not much compared to the midrange that you will pick up from them. IMO, the midrange is way more important and makes them a worthy mod for the money.
As long as you don't rev past the stock rev limiter, then you don't NEED R valvesprings....but it never hurts.
also remember, that R cams usually kill more aggressive cams in the midrange area.
Modified by WAFFLES at 2:37 PM 12/30/2003
Old Dec 30, 2003 | 01:16 PM
riceball777's Avatar
when i put ctr cams in my b16 i felt lil to no gains with a loss in low end
Old Dec 30, 2003 | 01:24 PM
WAFFLES's Avatar
Default Re: Will I get big gains in my B16 from ITR cams? (riceball777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 &raquo;</TD></TR><TR><TD CLASS="quote">when i put ctr cams in my b16 i felt lil to no gains with a loss in low end</TD></TR></TABLE>
keyword "felt"
Old Feb 1, 2004 | 01:01 AM
markdman's Avatar
what about putting itr cams into a b16 head?
Old Feb 1, 2004 | 05:23 AM
Default Re: (markdman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markdman &raquo;</TD></TR><TR><TD CLASS="quote">what about putting itr cams into a b16 head?</TD></TR></TABLE>
UMMM that's what this post is all about....Where else would you put the cams other then the head??
Old Feb 1, 2004 | 06:51 AM
Gabe_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CIVIC2 &raquo;</TD></TR><TR><TD CLASS="quote">
UMMM that's what this post is all about....Where else would you put the cams other then the head?? </TD></TR></TABLE>
In the oil pan!
Old Feb 1, 2004 | 08:14 AM
markdman's Avatar
I'm new to cam game. i heard some where its a good combination to run ctr cam on the intake side, and itr on the exhaust side. but arent the intake profiles the same?
Old Feb 1, 2004 | 09:15 AM
Gabe_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markdman &raquo;</TD></TR><TR><TD CLASS="quote">I'm new to cam game. i heard some where its a good combination to run ctr cam on the intake side, and itr on the exhaust side. but arent the intake profiles the same?</TD></TR></TABLE>
All CTR and ITR exhaust cams are the same.
2000+ ITR intake cams are the same as CTR's.
Here are the exact specs:
Civic Type-R And Integra Type-R(Integra Type R 2000/01 Spec)
Int-243 dur. / 11.5mm lift
Exh-235 dur. / 10.5mm lift
Integra Type-R(Through 1999 Spec)
Int-240 dur. / 11.5mm lift
Old Feb 1, 2004 | 01:13 PM
importboi22's Avatar
Default Re: (Gabe_)
when i put them in i didnt notice a but dyno difference.... had em in for a week, then when i went back to 1g b16 cams.... i almost cried after 5200 it just didnt kick like it used to with the R cams..... so verdict is
cant tell when you put em in..... CAN tell when you take em out
Old Feb 1, 2004 | 01:32 PM
Kendall's Avatar
You won't feel any significant gains with just the cams, but get a good header, a good intake manifold, a good throttle body, and maybe just a touch of headwork, and you'll never go back.
Old Feb 1, 2004 | 02:30 PM
highrolla's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">You won't feel any significant gains with just the cams, but get a good header, a good intake manifold, a good throttle body, and maybe just a touch of headwork, and you'll never go back.</TD></TR></TABLE>
Old Apr 11, 2004 | 06:27 AM
roadawg's Avatar
That is the truth.
I just got back from the shop and installed my ported skunk 2 IM, 2001 ITR cams, portflow springs and mild port work and it feels SOOO much stronger.
The midrange is like a different car
sicksiguy
Apr 24, 2006 12:08 AM
b16vtecsol
18
Mar 4, 2005 08:06 PM
HOTek9
Apr 22, 2003 08:11 AM
SuperCivic
19
Jun 28, 2002 07:09 PM
EF8SIR
Jan 30, 2002 11:30 PM
