96 accord heater problem
Old Oct 5, 2003 | 11:25 AM
khmertek's Avatar
Default 96 accord heater problem
my accord heater dont work
when i turn it on it just blows air out but no heat
can any one help?
Old Oct 5, 2003 | 09:07 PM
HONDADNA's Avatar
Default Re: 96 accord heater problem (khmertek)
Remove the heater **** and check if it's broken. It's a common problem on Honda's.
Old Oct 5, 2003 | 10:00 PM
Jago's Avatar
Default Re: 96 accord heater problem (HONDADNA)
The cable falls off mine all the time. I just pop the hood and
ajust the controll valve that way.
Old Jan 27, 2009 | 09:13 AM
JASIYAH6's Avatar
have that same problem where is the cable??
Old Jan 27, 2009 | 09:23 AM
JASIYAH6's Avatar
that and it was blowing heat this morning why not know?
plus the cable is connected..how far should it move back?
Old Jan 27, 2009 | 09:42 AM
spoon3rdgen's Avatar
if it's not blowing out constantly, your thermostat could be the issue. i just changed mines out and it's working beautifully.
Old Jan 27, 2009 | 10:02 AM
JASIYAH6's Avatar
just replaced the thermo stat and still does that...could it posibbly be a lower temp thermo?
Old Jan 27, 2009 | 11:32 AM
P_Adams's Avatar
You may have some air still trapped in the system and it stops circulation at idle or low speeds. Try purging the system and refilling.
P
Old Jan 27, 2009 | 03:15 PM
p adams that's true also. bleed the coolant line from the bleeder valve on the thermostat housing.
Old Jan 28, 2009 | 01:56 AM
JASIYAH6's Avatar
Ok i did chek the release valve and had no air in it slow steady stream.!!now what??
chauti
Dec 14, 2015 11:32 AM
TwoKSiR
Jan 22, 2009 11:49 AM
maddogtheman329
May 23, 2008 07:36 PM
mrak
Feb 5, 2008 05:01 PM
stivic
Nov 27, 2006 08:32 AM
