MPFI swap done but F'ed up... need answers
well i got my mpfi swap done a little while ago, i got a CODE4 which is crank angle sensor, i put b2 into b10 and b11 into b12, anyone gt any ideas??? can someone give me the color of the wires going to b10 and b12? also, i have a small coolant leek on the intake manifold, will it go away when it warms up? juwst a fyi, i'm running a D15B7 with a D15B1 rebuild head, Si cam, i have 3 different ecus (PM6, PM8, and a chipped 90 teg ecu), open header (exuast isnt finished) also the car has like no power, is this because of the crank sensor? also eratic idle when warm but i think thats the throttle body, i'm pritty sure i sawped the tps wires but i'll recheck. any help would be great!! tnx in advance
if thats the only code, you just need to keep double checking your wiring, the blue/green blue/yellow wires are the crank angle sensor wires, make sure they are in the correct pins on the ecu, and they are crimped/soldered good.
Jeff
Jeff
i thought the dizzy had the cyl. position sensor in it.. oh well i could be wrong, i'll swap them and see what happens
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sideout »</TD></TR><TR><TD CLASS="quote">i thought the dizzy had the cyl. position sensor in it.. oh well i could be wrong, i'll swap them and see what happens</TD></TR></TABLE>
It does.
It does.
i got it running now, i forgot to put C1 and C2 into B10 and B12, all i can say is OMFG!!! never run a honda open header!!! you'll go deaf fast, my friend 2.5mi away herd me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AbaZ »</TD></TR><TR><TD CLASS="quote">you just need to keep double checking your wiring
Do I get a cookie or something?
Way to go! I did exactly the same thing to my 89 Civic DX hb last year...change to MPFI, Si head and cam...definitely feel the difference especially higher rpm's, but definitely not a contender until you drop a ZC or B18 OR B20. But that's why I did
it...to get the car ready for a bigger motor.
Sorry I caught you too late...would've helped you.
civickid03
Jul 25, 2006 03:02 PM
blacksoul
Sep 10, 2002 08:25 AM
