GSR rear disc brakes
I've already bolted everything up and it fits but now i've encountered a problem with the rear left e brake cable... the stock one is a little short.... does anybody know what ebrake cable will fit with the setup?
If your using the 90-93 integra e-brake cables you should have no problem. They will even bolt up to the same mounting locations as your stock e-brake cables. Just make sure your running the cables the proper way. If your not running them the right way, this may be the reason your coming up short.
you can also try the ebrake cable off of a 90-91 crx si, that might work, Do you go down to belmont? were you there last weekend? This is matt with the red hatch if u were there.
oroca
Apr 2, 2009 12:10 PM
JLEK
17
Jun 11, 2007 09:58 PM
vtec94civic
11
May 4, 2004 06:53 AM
