B16A dizzy
Old Oct 5, 2003 | 06:19 AM
JDMHatch101's Avatar
Default B16A dizzy
I need to find out what dizzy that is interchangeable. OBD0 for JDMB16 thanks for the help in advance.
Old Oct 5, 2003 | 07:33 AM
turboZChatch's Avatar
Default Re: B16A dizzy (JDMHatch101)
91 ls will work
Old Oct 5, 2003 | 07:53 AM
Default Re: B16A dizzy (turboZChatch)
ive already got the 91 ls dizzy in the car now, but that is at a loss of power. i really want the dizzy made for the car. thanks anyways
Old Oct 5, 2003 | 08:07 AM
i dunno ive never had a problem (loss of power) with the ls dizzy
Old Oct 5, 2003 | 08:51 AM
my power loss is at hi revs. really at 6k and up. im stumped on this dizzy. thanks for the help.
Old Oct 5, 2003 | 08:56 AM
spaceman's Avatar
check your timing,get ngk or denso spark plugs,get a valve adjustment..
Old Oct 5, 2003 | 02:29 PM
R6Boy69's Avatar
I've got a B16 dizzy with a bad coil... PM if you want it... 60 shipped
Old Oct 5, 2003 | 09:14 PM
EF8_SiR's Avatar
I changed my whole dizzy to the ls as well, but had to shave off the "vtec solenoid" housing leg. Ur only other options is ebay for a b16a1 dizzy OR swap the si dizzy internals into teh B16 housing (i think). There were a few threads madeabout this problem
Old Oct 6, 2003 | 05:19 AM
ibanez_weirdo's Avatar
Default Re: B16A dizzy (EF8_SiR)
the sohc distributor will work just on the 3 ears that are on it you will haveto fabricate them a little and cut the bottom off with a portaband or something, all the sensors are the same as the b16's and the bearings/shaft all work out right, that is what im running on my b16 as e speak.
Old Oct 6, 2003 | 06:34 PM
Default Re: B16A dizzy (ibanez_weirdo)
first off is that a sohc vtec or none? second what years of sohc? third THANKS. and yes ive got new timing belt, belt tensioner, wter pump, oil pump, valves adjusted, so everything is good.
GroundZer0 336
May 18, 2009 05:20 PM
91 HONDAsaurus rex
Aug 6, 2008 06:09 PM
tRex99
Dec 31, 2004 02:57 PM
RACING INTEGRATION
Oct 27, 2004 06:52 AM
typeeg
38
Jun 18, 2004 11:37 AM
