whump-whump-whump-whump noise on tire revolution (I guess)
Old Oct 4, 2003 | 10:21 PM
m0dr0cker's Avatar
Default whump-whump-whump-whump noise on tire revolution (I guess)
Ever since I've bought my Civic, I've noticed that there is this "whump-whump-whump-whump-whump" sort of dull thudding noise that gets faster or slower depending on whether I'm going faster or slower. This correlation makes me think it might be something having to do with the wheels or tires. At highway speeds you can barely discern it since you're going so fast the sound just blends into itself, but if I'm breaking hard from 30 mph, I can really hear the "whump-whump-whump" sound.
Any idea what this could be?
Old Oct 4, 2003 | 10:42 PM
Ekay
Guest
Posts: n/a
Default Re: whump-whump-whump-whump noise on tire revolution (m0dr0cker)
i garuntee its warped rotor(s)
Old Oct 4, 2003 | 11:08 PM
m0dr0cker's Avatar
Default Re: whump-whump-whump-whump noise on tire revolution (AutoEK)
brake rotors? how much to fix?
Old Oct 4, 2003 | 11:23 PM
aw1234dude's Avatar
Any kind of steering wheel vibration?
Old Oct 4, 2003 | 11:24 PM
FWejCOUPE's Avatar
you could have a belt shift in one of the tires, i don't think it could be a brake problem because you would get a pulsation in the peddle or wheel when you slowed down at high speeds.
Old Oct 5, 2003 | 03:53 AM
nsxmatt's Avatar
Default Re: whump-whump-whump-whump noise on tire revolution (crxtc2020)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxtc2020 &raquo;</TD></TR><TR><TD CLASS="quote">you could have a belt shift in one of the tires, i don't think it could be a brake problem because you would get a pulsation in the peddle or wheel when you slowed down at high speeds.</TD></TR></TABLE>
Exactly. A "wump" at low speeds that increases with speed is usually a tire that has shifted a belt or has a flatspot from a lockup. A bent rim usually doen't show up until you build up speed and it's only a vibration. Best bet is to go to a shop that has a balancer that does a runout and road variance test and can detect imperfections in the tire itself. Sometimes you can rotate the tire to the rear and lower the noise but the tire needs to be replaced.
Old Oct 5, 2003 | 04:46 AM
00MRSi's Avatar
Default Re: whump-whump-whump-whump noise on tire revolution (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">
Exactly. A "wump" at low speeds that increases with speed is usually a tire that has shifted a belt or has a flatspot from a lockup. A bent rim usually doen't show up until you build up speed and it's only a vibration. Best bet is to go to a shop that has a balancer that does a runout and road variance test and can detect imperfections in the tire itself. Sometimes you can rotate the tire to the rear and lower the noise but the tire needs to be replaced.</TD></TR></TABLE>
I agree. Could it possibly be a wheel bearing?
Old Oct 5, 2003 | 04:58 AM
nsxmatt's Avatar
Default Re: whump-whump-whump-whump noise on tire revolution (00MRSi)
They usually cause a roaring roise that gets loud or quiet when you turn. If it's lost a bearing for some reason it could cause a thump noise. The wheel and hub should move quite a bit if you had it up in the air if that was the case. You can try moving the tires front to back and see if the noise moves also.
Old Oct 5, 2003 | 05:40 AM
2camsaam's Avatar
May be that one or more of your tires is going bad. My friends' tire had a tittie or bulge in the tire and it cause a sound similar to what you are discribing, also, it was a tad bumpy even on smooth roads.
Old Oct 5, 2003 | 05:50 AM
mathusala's Avatar
ever rotate the tires?
Old Oct 5, 2003 | 06:47 AM
_veilside_'s Avatar
Default Re: whump-whump-whump-whump noise on tire revolution (mathusala)
I also get this noise when driving on the motorway or slowing down to around 15mhp, is it something to do with noisy tyres or my rims are already bent? If the rims not seriously bent, will a balance sort things out?
Old Oct 5, 2003 | 08:17 PM
m0dr0cker's Avatar
Default Re: whump-whump-whump-whump noise on tire revolution (_veilside_)
I don't get any steering wheel vibration nor do I get vibration on the brake pedal.
I'm guessing that I need to go get my tires checked out and/or replaced then. I haven't rotated the tires because I only bought this vehicle (used) two weeks ago.
Thanks for the replies, folks.
Old Oct 5, 2003 | 08:54 PM
FifthGearOnline's Avatar
might be a flat spot as well
Old Oct 5, 2003 | 09:07 PM
Racerage1's Avatar
tires might be cupping(bumps on the inside of your tire).
bad alignment(toe, camber) could cause it
Old Oct 5, 2003 | 10:18 PM
Echo7847's Avatar
Default Re: whump-whump-whump-whump noise on tire revolution (2camsaam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2camsaam &raquo;</TD></TR><TR><TD CLASS="quote">May be that one or more of your tires is going bad. My friends' tire had a tittie or bulge in the tire and it cause a sound similar to what you are discribing, also, it was a tad bumpy even on smooth roads.</TD></TR></TABLE>
I believe he's right on the money
Old Oct 6, 2003 | 06:11 AM
m0dr0cker's Avatar
Default Re: whump-whump-whump-whump noise on tire revolution (Echo7847)
Just noticed on the way to work this morning, when I brake hard from a fast speed, I do get steering wheel vibration. Does that affect the diagnosis?
Old Oct 6, 2003 | 06:41 AM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
I'm gonna go ahead and throw out the good'ol CV joint cause. I know that my CV joint has been fuxed since christmas, and it makes a THUD THUD sound that goes faster and slower depending on how fast I am going. Could be the axle, but could very likely be the rotar.. Why don't you just take your wheel off and examine the rotar and axle. Look for grease on and around the axle.
Echo7847's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m0dr0cker &raquo;</TD></TR><TR><TD CLASS="quote">Just noticed on the way to work this morning, when I brake hard from a fast speed, I do get steering wheel vibration. Does that affect the diagnosis?</TD></TR></TABLE>
Warped rotors and possibly need an alignment.
Old Oct 6, 2003 | 06:58 AM
m0dr0cker's Avatar
Default Re: whump-whump-whump-whump noise on tire revolution (Hatchy-Ownzjo0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchy-Ownzjo0 &raquo;</TD></TR><TR><TD CLASS="quote">I'm gonna go ahead and throw out the good'ol CV joint cause. I know that my CV joint has been fuxed since christmas, and it makes a THUD THUD sound that goes faster and slower depending on how fast I am going. Could be the axle, but could very likely be the rotar.. Why don't you just take your wheel off and examine the rotar and axle. Look for grease on and around the axle.</TD></TR></TABLE>
I'll probably wind up doing that. I just needed a starting point.
I don't think it's a CV joint because I'd hear a clicking noise whenever I'd make a turn.
Thanks.
Partizan
Oct 28, 2008 10:59 AM
ruffrhyder
Oct 16, 2008 05:55 PM
DC2TEGGA-GSR
Mar 1, 2006 07:26 PM
William
Jan 26, 2002 10:50 PM
