URGENT!!! Car doesn't start
Old Oct 4, 2003 | 09:32 PM
DizDitto's Avatar
Default URGENT!!! Car doesn't start
I put an intake system in my 92eg yesterday. It was driving fine for a good 30-40 miles and so I parked it. Then when I jumped in the car and try and start it, it didn't start. It can't be the starter or the alternater because the car still makes all the noise that it should before starting, but the motor doesn't stay on...My friends and I have tried to see if the spark plugs were the problem but it wasn't. Could it be something to do with the fuel/gas injection? I don't know what's wrong. PLEASE HELP!
P.S. Yes, I am a newbie...Thankz
Old Oct 4, 2003 | 09:45 PM
FcUK It.'s Avatar
im confused, you say the motor doesn't stay on? so it does start and it dies? or it doesn't start at all? do you hear it rotate (sound of it starting)? please be specific
Old Oct 4, 2003 | 10:13 PM
daaznwhiteboi's Avatar
one of mah friends had the same thing and it was the spark plug wire..so i would definatly check the wires..have someone hold them all down and c if it stays on then let go. hope it helps!!
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
Default Re: URGENT!!! Car doesn't start (DizDitto)
are you throwing any sort of code??
Old Oct 5, 2003 | 07:51 AM
goodbyegti's Avatar
It could be the Fuel Pump Relay, hard to be specific with the info you've given..
Old Oct 5, 2003 | 08:31 AM
2camsaam's Avatar
Default Re: (goodbyegti)
I had the same issue.
Main fuel pump relay solved my problem.
Old Oct 5, 2003 | 09:06 AM
VTEk_TypeR's Avatar
fuel pump relay and do all the spark plug wired and spark plugs
Old Oct 5, 2003 | 09:19 AM
DizDitto's Avatar
I turned the ignition and hear it rotating and all but it doesn't "kicks" up and start. I have already changed the spark plugs and wires. I thought it might have been something to do with the distributor cap and rotor, so I changed those as well. My car still doesn't start. Is this more specific? Sorry for the inconvience of unspecified info
Old Oct 5, 2003 | 09:44 AM
2lua's Avatar
leave the key in the ingition and turn the key on but don't start the car. listen for your fuel pump to come on under the back seat it should make a whine for a second or two. if you have some one to help you this would be better though.
Old Oct 5, 2003 | 09:48 AM
goodbyegti's Avatar
then do a search for fuel pump relay, there are loads of posts about it...
Old Oct 5, 2003 | 09:57 AM
DizDitto's Avatar
Thankz everyone =D
Old Oct 5, 2003 | 03:18 PM
BarelyGlowin's Avatar
Default Re: (DizDitto)
have you checked the o2 sensor? I've seen that happen when that wasn't plugged in....
Old Oct 5, 2003 | 06:37 PM
Jimmy's Avatar
Global Moderator
Default Re: (BarelyGlowin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BarelyGlowin &raquo;</TD></TR><TR><TD CLASS="quote">have you checked the o2 sensor? I've seen that happen when that wasn't plugged in....</TD></TR></TABLE>
Have you checked your ***...b/c your talking out of it
Old Oct 5, 2003 | 07:28 PM
Jeffro_93's Avatar
also make sure the cold air is on tight in all places. cause if it isnt on at all or too much air gets through it the car wont start either.
Jeffro
Old Oct 5, 2003 | 08:04 PM
jus f0 dekarayshunZ
Default Re: URGENT!!! Car doesn't start (Jeffro_93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeffro_93 &raquo;</TD></TR><TR><TD CLASS="quote">also make sure the cold air is on tight in all places. cause if it isnt on at all or too much air gets through it the car wont start either.
Jeffro</TD></TR></TABLE>thats not right...you can run with no filter just "open throttlebody" and the car would still turn on ...so survey says...wrong answer
Old Oct 5, 2003 | 09:30 PM
HONDADNA's Avatar
Have you tried checking for spark? if you do do check your fuel.
One quick way to check for fuel flow is remove the on the fuel filter, this will also check the operation of the main relays fuel pump circuit operation, have someone turn the key on and fuel sound flow alot. if it goes most likely your relay is fine.
Old Oct 9, 2003 | 10:21 PM
Default Re: (USDMDC2)
think so? go see how long your car runs with the o2 sensor out.....
same ol' civic
Jun 5, 2005 07:29 AM
93egsi
11
Jun 18, 2004 05:37 AM
Spooled1.6L
Apr 20, 2004 05:49 AM
nitroacc0rd
Mar 1, 2003 11:08 AM
