Loud Rattle...
Old Oct 4, 2003 | 07:11 PM
quikrpm'z's Avatar
Default Loud Rattle...
Its so loud that the cars around me look over to see whats making the noise. Im assuming its the catalytic converter (3" carsound). Anyone else had a problem like this? How loud is rod knock? What do u guys think it might be. tia.
Old Oct 4, 2003 | 07:31 PM
Loveless's Avatar
Default Re: Loud Rattle... (quikrpm'z)
heat shield rattling?
Old Oct 4, 2003 | 08:06 PM
quikrpm'z's Avatar
Default Re: Loud Rattle... (Loveless)
ive heard the heat shield rattle before, but never this loud. kinda sounds like cans dragging.
ok hit the catalytic with a mallet and it definately rattles. Can anyone recommend a better cat then carsound?
Modified by quikrpm'z at 10:21 PM 10/4/2003
Old Oct 5, 2003 | 03:34 AM
Outkasted24's Avatar
Check the "L" bracket coming off the top of the header and bolting to the back of the block.
I had that problem too, I had to grow some ***** and clime up under the car while my buddy reved the motor to find out exactially where the vibration was coming from.
if thats it (I've had two friends with the same exact problem) you might have to take the bracket out...find where the paint is worn down and Dremel that piece off.
It could also be your cat. touching the Swaybar or shift linkage, I've seen these problems also with my own two eyes.
Good luck and let us know what it is if you find it.
Peace
Old Oct 5, 2003 | 05:19 AM
ggangtong81's Avatar
Default Re: Loud Rattle... (Outkasted24)
it might be the cat converter pipe taht goes inside the header to seal the pipe.the pipe where cat converter was too long and it was hitting the walls of header for me. i have to replace the cat converter too.
patrEK9
18
Mar 30, 2010 09:15 AM
Redprelude98
Jan 1, 2009 02:31 PM
jugodmyko
13
Sep 21, 2007 05:23 AM
davidjaii
Oct 17, 2003 10:44 PM
LOWLIFEHATCH
Dec 11, 2002 01:03 PM
