CAn the car really be this lean :O
Ok well setup ctr's in a ls/vtec, just wondering if with stock injectors it would be so lean that the a/f guage woundnt even register at idle. AT idle its off the scale in the red, i take the afc to like +50 and it slightly flickers in the red. I know the a/f guage doesnt mean crap but still its kinda weird, not sure if the a/f guage is broke or the o2 signal is jacked up. Even with a volt meter the o2 voltage is really low( i have no cel's). Wont have a wideband for a couple more days, so just wondering.
yes its possible with that compression. but you should see what happens when the engine is under load. but then again those guages are funny. only the wideband will tell the truth.
