WHERE CAN I GET ECU PINS FOR OBDO!!!!! Please Help Quick!!!!!
I need to know where to get some ECU pins or something that will work for PINS. I've got the B16a mounted and the only thing I have to do is wire the Vtec sol and pressure switch. Also does the black wire on the pressure switch go to a ground and the blue wire go to the ECU? PLEASE HELP I REALLY NEED IT!!! Thanks. The Japanese harness didn't come with the plugs to the ECU so I can't borrow them!
PM blown90hatch ...he makes obd2-1 conversion harnesses, custom harnesses, and i'm sure he has these obd0 pins
racingant
Aug 12, 2005 05:12 PM
