How to add HID to my EG?
Old Oct 4, 2003 | 06:23 PM
nickgomez's Avatar
Default How to add HID to my EG?
I've been thinking of how to add HID to my 94 EG hatch. What would be the best kit out there? I want a true HID. Is Philips Xenon equal to HID? Its quite confusing. I don't want to spend money on some silly blue bulbs.
Old Oct 4, 2003 | 08:57 PM
VTEC-DA's Avatar
Default Re: How to add HID to my EG? (nickgomez)
There are true HID kits, and there are bulbs that give a HID "look". You will know a true HID kit when you buy it, they arent cheap.
Old Oct 4, 2003 | 09:15 PM
phantom_sol's Avatar
a true hid system will require a ballast and usually a d2s or d2r bulb. get a shield that will adapt tp your headlights (h4) it may also make for a better cutoff line. aftermarket clear (non-fluted) lenses will help too.
Old Oct 6, 2003 | 12:10 AM
JDMlyfestyle's Avatar
Ive noticed that the OEM retro fit kits look way better than the aftermarket ones.
Old Oct 6, 2003 | 04:48 AM
I30 projector in del sol headlights
unfortunately no unfluted lense cause there are no aftermarket headlights available
you can get unfluted oe style headlights for civics (96+ already has them stock) but theres no love for the sol.
Old Oct 6, 2003 | 06:35 AM
darkjedi022's Avatar
Default Re: (phantom_sol)
i haev hella.....they are the best that i have used for more than 5 years...chk oout http://www.misterjung.com/
Old Oct 6, 2003 | 06:47 AM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: (darkjedi022)
You will need to either get an H4 HID kit or get H4 Adapters. I would say go with OEM HIDs(Honda, BMW, Audi etc..). And get the H4 adapter/shield so that you don't completely blind the **** out of all oncoming traffic. I have this set up, and I'm not too happy with it. I'm in the middle of doing a retrofit type project.
For best results get some Projector headlights and retrofit in some OEM Projectors. That means you get projectors from an S2000 or BMW and replace the crappy foglight projecters that will come in any and all projecter headlights you buy for your civic with the OEM projectors. This will give you the best lighting and cutoff you can get.
Old Oct 6, 2003 | 06:55 AM
BECAUSE THE LENSES ARENT FLUTED.
(WE USE CAPS AT WORK I WAS JUST TOO LAZY TO TURN THEM OFF)
B16marley
Lighting
Jan 29, 2011 11:08 AM
egdriver94
Jun 23, 2007 07:09 PM
matt21civ
Honda Civic (2001 - 2005)
Jul 24, 2006 05:29 AM
EX-JAY
Mar 19, 2005 07:50 PM
