idle fluxuating
Old Oct 4, 2003 | 06:02 PM
pinoyboy204's Avatar
Default idle fluxuating
hello. i just recently had my car checked up with a couple of my boys and yea, my car fluxuates at around 1500 to 2000 rpm. what could cause the idle to fluxuate and how can i fix it? btw, i also noticed that when i get into the first gear, it feels like its so rough, but when you hit the gas at around 4 or 5, it feels smoother. i need all the help i can get. thanks.
Old Oct 4, 2003 | 06:09 PM
neutron91's Avatar
Default Re: idle fluxuating (pinoyboy204)
have you set the idle... you said it fluctuates from 1500-2000... the only time the rpms should be that high is when you first start it up or when you are driving it, not at idle... so check that first... if thats not it then check for a vacuum leak... you might want to check the timing and valve adjustment just to rule things out... if that fails, it could be a burned exhaust valve(s)
Old Oct 5, 2003 | 06:12 PM
Default Re: idle fluxuating (neutron89)
could it be a bad intake manifold gasket? oh and btw, it fluxuates and idle's at 1000 to 1500 when in idle.
Old Oct 5, 2003 | 08:12 PM
now i am getting
code 14
and code 16...how can i fix this? please post pics.
em1gangsta
Jan 26, 2008 03:40 PM
rice a roni
Apr 15, 2005 09:49 AM
Civic Racer X 7
Jul 23, 2003 07:19 AM
Spade
Jul 1, 2002 10:49 AM
vti-R
Jun 21, 2002 08:01 PM
