gsr brake conversion from cx eg brake lines?
hey guys i have already did a search and dont remember reading anything about a different size brake line that goes into one oneside of the mc but one side seems larger? Also we rounded off some of the brake line nuts when trying to get them off even with a flare nut wrench wtf? Any ideas or do i have to buy all new brake lines?
on the gsr mc have 2 difference brake fitting. if you round out you have to cut the line and use new nut and reflare the brake line. you might get away with reflare the line. it gona be ugly, but try to put it back slow by hand then use visegrip the tighten it up, and make sure it not leaking.
it depends if its abs or not. if its non abs the fittings are the same, if its abs, then theres one that would be larger. they do have adapters. go to local parts store.
citanest
Oct 19, 2001 08:25 AM
