195/45/15 kumho ecstas....195/50 es100
do you want to know which is better, which is worse, which costs more, which will pick you up more chics, which one is blacker, which ones will last longer, which ones ride harder, which ones for rain, which ones for dry,
This isn't English 025, ask a clear question and you'll get clear answers
if you running b-series, then definatly 195/50R15. d-series can be used with the 45 profile, but remeber load capacity will change with the profile. therefore lower the proflie the lower load carrying capacity.
right now im runnin stock d series....dont palnt to do swap until spring 04....so i dunno....if im plannin on lowering my ride a lot will 50s clear ok with 0 degree camber.
im ordering tomarrow so sorry if im goin crazy with this subject
just want to go real low and have no issues + performance..thanx
195/45/15 is way too small. I even think that 195/50/15 is too small. Both will throw off your speedometer. Go with 195/55/15. This is the stock 15" tire size and you can get Ecstas and ES100s in this size.
I would go 205\50. Just a bit wider and supply a bit more grip. Wont rub if you have factory camber setting. As close to zero as possible in the front and negative 1 in the back.
all that im sayin is that i dont want to dump my ride and adjust camber as close to 0 as possible and rub... thats why im concerned with the size soo much.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EricUSC »</TD></TR><TR><TD CLASS="quote">195/45/15 is way too small. I even think that 195/50/15 is too small. Both will throw off your speedometer. Go with 195/55/15. This is the stock 15" tire size and you can get Ecstas and ES100s in this size.</TD></TR></TABLE>
Judging by his avatar I'm assuming he has a 5G Civic, with 195/50-15 being practically the same rolling diameter as stock.
the 195/45/15s would be a lot better. It would actulat help the gearing of the car. Stock tire size is 22.6" and the the 195/50 would be like stock 22.6" but the 195/45's would have a 21.9" diameter. Its like getting a better final drive
I'm foreal though.
I'm foreal though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6ajk »</TD></TR><TR><TD CLASS="quote">if you running b-series, then definatly 195/50R15. d-series can be used with the 45 profile, but remeber load capacity will change with the profile. therefore lower the proflie the lower load carrying capacity. </TD></TR></TABLE>
I'm sure this isnt his work truck. From the look of that avatar he has, It is prolly a gutted hatch w/ 1 seat
45's !!
45's !!
How is 50 series too small? lol its stock tire diameter. and the 45's will be fine. trust me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outrun »</TD></TR><TR><TD CLASS="quote">
Judging by his avatar I'm assuming he has a 5G Civic, with 195/50-15 being practically the same rolling diameter as stock.</TD></TR></TABLE>
thank god, we have some smart tire peopel here
45's though
would make it like you have better gearing!
(sorry, I'm very bored and I havent had power in forever because of the hurricane here on the east coast)
45's though
would make it like you have better gearing!(sorry, I'm very bored and I havent had power in forever because of the hurricane here on the east coast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Typesi2nv »</TD></TR><TR><TD CLASS="quote">the 195/45/15s would be a lot better. It would actulat help the gearing of the car. Stock tire size is 22.6" and the the 195/50 would be like stock 22.6" but the 195/45's would have a 21.9" diameter. Its like getting a better final drive
I'm foreal though.
Nah, these are the correct diameter:
195/45/15 - 21.91"
195/50/15 - 22.68"
205/50/15 - 23.07"
195/55/15 - 23.44" - stock diameter
Check here for the tire diameter calculator:
http://www.rx7turboturbo.com/r...r.htm
I'm foreal though.
</TD></TR></TABLE>Nah, these are the correct diameter:
195/45/15 - 21.91"
195/50/15 - 22.68"
205/50/15 - 23.07"
195/45/15 - 21.91"
195/50/15 - 22.68"
205/50/15 - 23.07"
http://www.rx7turboturbo.com/r...r.htm</TD></TR></TABLE>
lol... ok smarty
jk. same figures i was getting. But I still do think stock Diameter is 22.6" Try factory tire size of the 14 or 13" wheel/tires.
195/45/15 - 21.91"
195/50/15 - 22.68"
205/50/15 - 23.07"
lol... ok smarty
lol... ok smarty
Actually, you're right for the 13" tires. The 13" tires have a smaller diameter while the 14" and 15" tires are almost an inch larger in diameter. So I guess if you have a 92-96 Civic CX or DX, 195/50/15 would be the perfect match as far as tire diameter. I guess I never thought much about 13" tires because my car came stock w/ 14" tires. Here are the diameters according to the calculator link I posted above:
175/70/13 - 22.65"
185/65/14 - 23.47"
195/55/15 - 23.44"
lol... ok smarty
</TD></TR></TABLE>Actually, you're right for the 13" tires. The 13" tires have a smaller diameter while the 14" and 15" tires are almost an inch larger in diameter. So I guess if you have a 92-96 Civic CX or DX, 195/50/15 would be the perfect match as far as tire diameter. I guess I never thought much about 13" tires because my car came stock w/ 14" tires. Here are the diameters according to the calculator link I posted above:
175/70/13 - 22.65"
185/65/14 - 23.47"
195/55/15 - 23.44"
175/70/13 - 22.65"
185/65/14 - 23.47"
195/55/15 - 23.44"</TD></TR></TABLE>
yeap. I was figuring up the 13's
My EX had 185/60/14's on it but those wernt factory tires, they were 22.7 I believe.
175/70/13 - 22.65"
185/65/14 - 23.47"
