Turbo Flange stripped, re-tap?
Old Oct 4, 2003 | 03:23 PM
KOALA YUMMIES's Avatar
Default .,
Old Oct 4, 2003 | 03:26 PM
Mase's Avatar
Default Re: Turbo Flange stripped, re-tap? (KOALA YUMMIES)
you can try to retap w/ the same size, you may have to go to something larger if its that messed up
Old Oct 4, 2003 | 04:05 PM
ImAcracker's Avatar
Loved
If your threads are completly fucked then you will have to tap the hole to a bigger size and use a heli coil. I dont know how well a heli coil will work on a flange though. In other words Im not sure if it will just screw out the other side of the flange. You could probably get it to work though. Just **** with it some. It worked fine on my exhaust manifold to head bolts.
Old Oct 4, 2003 | 06:37 PM
accordking's Avatar
Default Re: Turbo Flange stripped, re-tap? (ImAcracker)
time serts work wonders. they're better than helicoils.
Old Oct 4, 2003 | 07:09 PM
Ri5e's Avatar
Default Re: Turbo Flange stripped, re-tap? (accordking)
how did u strip it?
Old Oct 4, 2003 | 07:11 PM
rjardy's Avatar
contact cody to get a new flange welded on.
Rob
Old Oct 4, 2003 | 07:48 PM
DaveF's Avatar
Default Re: Turbo Flange stripped, re-tap? (rjardy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjardy &raquo;</TD></TR><TR><TD CLASS="quote">contact cody to get a new flange welded on.
Rob</TD></TR></TABLE>
seems like a waste of money....
is there any way to put a longer bolt in the hole and than put a nut on the backside instead of using the manifold threads..
if not than use the heli coil method..that **** works.
Old Oct 4, 2003 | 08:05 PM
ImAcracker's Avatar
Loved
Default Re: Turbo Flange stripped, re-tap? (2.2Lcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2Lcivic &raquo;</TD></TR><TR><TD CLASS="quote">
if not than use the heli coil method..that **** works.</TD></TR></TABLE>
Agreed. Thats just too much work for a bolt whole. If he cant fit a bolt behind it than a heli coil would do the trick if he feels like ******* with keeping it lined up with the hole.
Old Oct 4, 2003 | 09:36 PM
ImAcracker's Avatar
Loved
Those dont look to bad. A tap should be able to clean that right up.
Old Oct 5, 2003 | 12:17 AM
rjardy's Avatar
Old Oct 5, 2003 | 06:15 PM
boostedcvc's Avatar
The bolts that screw into my sfp manifold actually broke off in the manifold and i had to get them machined out. We were able to retap all but one of them and the one we had to use a heli coil. To prevent anymore bolts from getting stuck in the flange we decided to use studs and brass nuts. This worked rezally well and i'm no longer worried about getting the damn bolts in and out.
Old Oct 6, 2003 | 11:29 AM
Mr. Softee's Avatar
Default Re: Turbo Flange stripped, re-tap? :Edit: Pics now! (KOALA YUMMIES)
id just use a slightly larger tap on all of those... im guessing those are m8 i think threads? use the american equiv, it should be just a tad larger. should have 0 problems.
sam
Old Oct 6, 2003 | 07:19 PM
Tinker219's Avatar
Default Re: Turbo Flange stripped, re-tap? :Edit: Pics now! (94goldjungsr)
they are 3/8X24 tpi, SO...maybe use a 14mm honda bolt? They are close(and probably what caused the original strippage), and w/force will go in. I say get some studs/nuts, get them in as best you can, and be done....
Old Oct 6, 2003 | 07:22 PM
Mr. Softee's Avatar
Default Re: Turbo Flange stripped, re-tap? :Edit: Pics now! (Tinker219)
i had to use metric bolts w/ your manifold, the american sizing ones at ace did not fit. it caused strippage of two threads
sam
Old Oct 6, 2003 | 07:25 PM
Tinker219's Avatar
thats very odd, you sure you had a fine thread(24 TPI)? Maybe Ill just switch over to a metric style thread to begin with. I chose the american thread because almost EVERY hardware store has that size...Sam, do your bolts go in and out easily now???
Old Oct 6, 2003 | 07:27 PM
Mr. Softee's Avatar
manifold is sold bro.
and i did use fine thread (had to with the metric)
they just didnt have the right size or something... it was barely too small. i figured you had just chosen to use the 14mm (m8), but it was a VERY tight fit and i fucked up the threads extremely badly on one of the taps
sam
evoeone's Avatar
too bad you couldnt get a nut behind it, my aftermarket turbo manifold is theraded and then i use a bolt on the otehr side and NO loosening what so ever
Old Oct 6, 2003 | 07:31 PM
Mr. Softee's Avatar
Default Re: Turbo Flange stripped, re-tap? :Edit: Pics now! (evoeone)
thats what i ended up doing... it worked just the same.
kreatekustomz
Nov 23, 2009 05:44 AM
85
Feb 22, 2007 06:59 PM
Jays91DXhatch
Jan 8, 2006 06:07 AM
streetlvlhatch
Feb 29, 2004 05:35 PM
rice a roni
Dec 28, 2003 01:40 PM
