where does this line go off the t-body?
Old Oct 4, 2003 | 01:06 PM
Rob Dizzle's Avatar
Default where does this line go off the t-body?
i thought it went to the IACV, but i dont think it does
anyone?
Old Oct 4, 2003 | 02:17 PM
IN VTEC's Avatar
Default Re: where does this line go off the t-body? (Bob-DC2)
Intake manifold, next to the #4 cylinder.
Main water pipe - IACV - TB - Intake Manifold/Cylinder Head
Old Oct 4, 2003 | 02:35 PM
HaUTSaauce's Avatar
New User
Default Re: where does this line go off the t-body? (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Intake manifold, next to the #4 cylinder.
Main water pipe - IACV - TB - Intake Manifold/Cylinder Head</TD></TR></TABLE>
Old Oct 4, 2003 | 04:34 PM
Rob Dizzle's Avatar
Default Re: where does this line go off the t-body? (HaUTSaauce)
problem was, i had a obd2 gsr intake manifold, without that bung.
luckily i have a stripped down obd1 IM laying around that i can re-assemble and get it going again
Old Oct 4, 2003 | 05:58 PM
IN VTEC's Avatar
In that case, let me take some pics for you.
brb
From what I tell you in writing, the OBD-2 coolant routing goes:
Main water pipe -&gt; IACV -&gt; TB -&gt; PCV heater -&gt; upper radiator housing
Old Oct 4, 2003 | 06:13 PM
IN VTEC's Avatar
OBD-1
OBD-2
The OBD-1 uses a PCV heater from the thermostat housing. OBD-2 uses a PCV heater from the TB. OBD-2 is slightly simpler.
Old Oct 4, 2003 | 06:15 PM
Rob Dizzle's Avatar
its okay
i have an extra obd1 laying around
im just going to put it on
one of the studs on the head for the intake manifold is toast
so i cant get the bolt off
jpm3071
10
Jun 9, 2015 12:39 PM
integlspwr2k
Feb 22, 2014 05:18 PM
MaGoodc2
Oct 29, 2004 08:27 AM
