Synthetic Oil in a 03 Civic EX?
Old Oct 4, 2003 | 01:03 PM
ambat's Avatar
Default Synthetic Oil in a 03 Civic EX?
I used the search function and could not find much info on using full synth oils on Honda Cars.
Do folks switch to full synth at the very first oil change? Or is it not the norm for Hondas.
I have been running full synth (Mobil 1 5w30) on my VW Jetta 1.8T ever since its first change and i drive the Civic much much more than the Jetta (about 350 miles a week). So should i switch to synth or synth blend on its first oil change for the civic too?
Also the manual says that the first change is only due at 10K miles, since I put in a lot of miles it, should I change sooner?
Thanks
Old Oct 4, 2003 | 01:08 PM
solo2slocivic's Avatar
run your first change at 5k then change around every 5k read a little deeper 10 is under normal driving conditions and u drive more tjan normal... just dont dump the oe oil until 5k
Old Oct 4, 2003 | 02:58 PM
rus's Avatar
rus
Default Re: Synthetic Oil in a 03 Civic EX? (ambat)
Synthetic blend is a ripoff, since no manufacturer actually provides the proportion of synthetic oil to the conventional oil. Could be 1%, could be 99%, but still most likely 1%. You might as well run conventional with one drop of synthetic - that would make it a "blend".
You don't want to run your oil for more than 5k, regardless whether it's conventional, blend, or synthetic.
Rus
Old Oct 6, 2003 | 06:57 AM
ambat's Avatar
Default Re: Synthetic Oil in a 03 Civic EX? (rus)
Thanks guys will change oil at 5K.
But the second part of the question still remains? Do folks use Synthetic in their Civis (or Hondas in General) or do folks stick with Dino.
Old Oct 6, 2003 | 07:01 AM
SOHC_MShue's Avatar
i have been using full mobil 1 synthetic on my 98 civic for the past 2 oil changes.
Old Oct 6, 2003 | 04:50 PM
JMD's Avatar
JMD
I have a 98 ex and I just switched to Mobil 1 and i haven't had any problems. Actually feels like it runs better.
Steve26
Jul 21, 2004 03:02 PM
return_2020
Jul 14, 2004 04:19 PM
Behan
Sep 9, 2003 05:10 AM
GQ 05YellowEVO8
May 24, 2002 06:25 PM
mickey513
Oct 5, 2001 10:11 AM
