J30 manuel trans possibilities
Old Oct 4, 2003 | 12:22 PM
K20EG's Avatar
Default J30 manuel trans possibilities
what is going to fit on a J30 accord motor
manuel transmission wise ?
anyone
Old Oct 4, 2003 | 03:15 PM
Nick H's Avatar
New User
Default Re: J30 manuel trans possibilities (K20EG)
i think the legend v6 manual transmission bolts up...
Old Oct 4, 2003 | 03:37 PM
K20EG's Avatar
Default Re: J30 manuel trans possibilities (Nick H)
...tight thanks man
Old Oct 4, 2003 | 10:34 PM
pogidawgie's Avatar
This has been done already. Go to http://www.v6performance.net and search for post by Jimmyrecluse. He used an Acura TL 6 speed manual tranny and he has the complete rundown on how it was done.
Old Oct 5, 2003 | 09:54 AM
INFAMOUSImage's Avatar
The 95 Legend tranny was done, but nothing positive came out of it. The guy had a lot of problems with the Stock Accord ECU not being able to read a 5th gear. If you were really to do this the best thing would be it to try to also swap the Legend 5spd ECU also. I don't know if that is possible but with out a 5spd ECU the car won't run right.
Old Oct 5, 2003 | 10:10 AM
K20EG's Avatar
Default Re: J30 manuel trans possibilities (INFAMOUSImage)
this particular car will be running on a speedpro
as long as the legend 5spd bolts up ..
i heard even the TL 6 speed will bolt up
Old Oct 5, 2003 | 01:49 PM
The 6sp won't bolt up. The tranny is a little too big. I know someone who did a FULL 3.2TypeS Motor/Tranny/ECU swap. That worked VERY good. In the ammount you are going to spend on a Legen 5spd and labor and **** its not even worth it. The kid who did the swap a while back spent close to 5g's on the tranny swap. You will need to have someone make custom tranny mounts, you have to add the clutch pedal, and find an ECU that works with the extra 5th gear. Its alot to spend just for a tranny. The kid who did the full TypeS swap olny cost him 6g's. 4g for the Motor/Tranny/ECU/Clutch Pedal/etc. and about 2g's to make new mounts and do the full swap.
Old Oct 5, 2003 | 02:36 PM
pogidawgie's Avatar
Here's the link on how Eric (Jimmyrecluse) did it and some idea on cost.
http://www.v6performance.net/f...27925
Old Oct 5, 2003 | 02:45 PM
Nick H's Avatar
New User
Default Re: J30 manuel trans possibilities (pogidawgie)
the 94 and 95 legends were 6 speed...the pre 94 were 5 speed...
Power Rev Racing
Apr 24, 2006 08:10 PM
speedshift86
Dec 13, 2004 06:44 AM
red civic standard
Mar 13, 2004 01:41 PM
5150CRX
Dec 15, 2002 01:18 AM
kikkoboyie
Apr 19, 2002 10:44 PM
