1 piece header?
Old Oct 4, 2003 | 09:40 AM
teknikEG6's Avatar
Default 1 piece header?
Everyone is tellin me that one piece header is really annoying to put on, is this true? Im lookin at a greddy one, what are some other good brands, and should i just pay the extra to get a 2 piece?
Old Oct 4, 2003 | 09:43 AM
NiiS's Avatar
Default Re: 1 piece header? (teknik_civic)
If j00 get a one piece header, chances are good the weight will be very minimal, meaning mounting it from underneath will essentially easier, just a matter of angles...But that`s just my opinion..
Old Oct 4, 2003 | 09:58 AM
EG2 SiR's Avatar
Default Re: 1 piece header? (Sin 2)
depends on the car your putting it in. I had a 1pc light speed header in my old CRX that you had to finesse to get it in. My DC 4-1 pc installs into my Del Sol like cake.
what car is it going in?
Old Oct 4, 2003 | 11:20 AM
JICEK9's Avatar
Default Re: 1 piece header? (EG2 SiR)
it's really not hard at all... and you only have to put it on once get what you want
Old Oct 4, 2003 | 11:27 AM
rodrez.'s Avatar
It really does depend on the car. For example a one piece header is little more of a hassle to install on a B16 in a CRX, but very easy to put on a 93 CX w/a B16, because of the amount of room.
Old Oct 4, 2003 | 12:19 PM
Ricey McRicerton's Avatar
Default Re: 1 piece header? (rodrez)
I say get the 2 peice just incase you have to pull your oil pan if for no other reason. Having to pull off your header to get the oil pan off would suck!!
Old Oct 4, 2003 | 12:22 PM
EG2 SiR's Avatar
Default Re: 1 piece header? (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">I say get the 2 peice just incase you have to pull your oil pan if for no other reason. Having to pull off your header to get the oil pan off would suck!!</TD></TR></TABLE>
Pulling off your header is a ridiculously easy task... 9 12mm's and 2 14mm bolts w/12mm nuts???? maybe I'm wrong... but isn't a 1pc a superior design? (ex: itr stock exhaust mani)
Old Oct 4, 2003 | 12:26 PM
Caveman74's Avatar
You can get a one piece, But it is a pain in the *** to put in. You will have to go from underneith the car. Two piece is much easier.
Old Oct 4, 2003 | 12:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2 SiR &raquo;</TD></TR><TR><TD CLASS="quote">
Pulling off your header is a ridiculously easy task... 9 12mm's and 2 14mm bolts w/12mm nuts???? maybe I'm wrong... but isn't a 1pc a superior design? (ex: itr stock exhaust mani)</TD></TR></TABLE>
I don't know..but I had the DC 4-2-1 ceramic coated header and loved it!
Old Oct 4, 2003 | 12:51 PM
GSRswapandslow
Guest
Posts: n/a
how sad
you have to be under the car with EITHER header. how are you going to connect it to the exhuast if you aren't? you're not
a 4-1 is better....it's lighter. it also doesn't have to worry about the area where the two sections would be bolted together. That can casue turbulance or a restriction.
ohh, and DC headers are cheap **** that really don't make much power, other than the 2.5" collector one. and if 2 piece was better...then the big companies like headertech, an-r, dtr, etc... would use a 2 piece instead of the 1 piece that all go with
Old Oct 4, 2003 | 01:14 PM
D16Z6racing's Avatar
Default Re: (Caveman74)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Caveman74 &raquo;</TD></TR><TR><TD CLASS="quote">You can get a one piece, But it is a pain in the *** to put in. You will have to go from underneith the car. Two piece is much easier.</TD></TR></TABLE>
Hahaha, maybe for the mechanically challenged.
I got my 1 piece DC header on my 93 Civic from the top. 1 little scratch that wasn't even noticeable.
Old Oct 4, 2003 | 01:35 PM
EX-T's Avatar
Default Re: (D16Z6racing)
I have an Apex'i GT Spec 1 piece header, and it wasn't hard at all to put in...but it helped that I work at an Xpress Lube and I didn't have to jack the car up to put it in...
Old Oct 4, 2003 | 05:57 PM
EG TYPE-R's Avatar
Default Re: (DSeriesBKilla)
all you need to do is jack the car up.
put the header on then tighten all the bolts.
very simple task
Lucky-13
Feb 12, 2007 10:21 AM
crxtreme89h
23
Aug 14, 2005 01:17 PM
Timmayeg
May 5, 2003 08:12 PM
ScottEK
Oct 20, 2002 08:35 PM
