fuel pump install on a b16a1 swap in an ef
Do a search. I've explained how many many times in posts.
https://honda-tech.com/zerothread?id=409859 - raene's post.
yeah i tried doing a search...but I guess I used the wrong wording for the search. That post didn't come up. Thanks though. And yeah I heard I might have to replace the straps that hold the tank too. Thanks.
walbrough( walbro?) fuel pump for b16, don't go with stock, and yes buy all the nuts and bolts for the straps, new from honda before you start, it's easier on a lift hoist but not impossible on the ground, run the tank till it's on E for weight ease
hey, what problems accured to you beofore you noticed you had to change your fuel pump??? I might have a fuel pump problem too, since you needed one for your B16 too, maybe this can be a common problem for us 16 owners.
thanks
***civic Nation**
thanks
***civic Nation**
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cvc323 »</TD></TR><TR><TD CLASS="quote">walbro, I think thats it. What do you think of BBK or a Holley fuel pump? same diff?
bump</TD></TR></TABLE>
They are all the same, Walbro makes the fuel pumps for BBK and Holley. BBK and Holley just put their name and labeling on them. Look on Ebay, the pumps can be found for under $100.
94lvstreetscene
Nov 10, 2006 12:55 PM
