What the difference between sc61 t3/t4 ar.69 and sc61 straight t4?
What output/ power levels could be achieved by moving up to the t4?
This is going in a 84mm 10:1 compression B18c1 motor. 600 HP is the goal.
Is a t4 necessary?
Going to use a custom equal length manifold. Will lag be a problem?
Is a t4 necessary?
is this going to be a street car? I don't know if anyone has made 600whp yet with an sc61, you may want to consider an SC63 or PT67 depending on the car's usage.
Going to start off as a street car. Needs to have a/c and p/s. Will definitely end up as a race car. That's why I am considering a t4 based turbo setup. The manifold will be $$$$. I don't want to have to get another one. Bought and sold too many cars. This one will be a keeper.
This is going to start off as a street car with a/c and p/s. It will definitely end up as a race car. I will be getting a custom ss equal length manifold done. That's why I am contemplating a t4. I don't want to spend a lot of money on a manifold twice. Been through this too many times with other cars. I want a platform that will satisfy me for time to come. The car will probably be driven 3-4 days a week, but not exclusively. I have another car.
I think you need something bigger than the SC61.
I'd say T4, but contact motormatrix, he can help you out.
The most whp Ive seen on the sC61 with a 76 trim T350 is 530whp by hybrid 901. Brian Ballard ran a 146mph with his SC61 turbo'd CRX T4. I dont know what turbine wheel he is using.
if you have anymore questions either me or Motormatrix can help you out.
art
art
I will be trying to make 600+ here very shortly on my T4 SC61 .70 A/R T04S compressor .81 A/R T housing P trim...my setup is similiar except I am running 83mm bore and my block is stroked.
-Ryan
-Ryan
I think to make 600whp in a SC61 you'll need about 32-35psi, which I intend to run but I dont think I'll get 600whp.
Now, I dont know how much power Brian Ballard is making, but the most Ive seen on a T3 SC61 with T04E housing is 530whp at 24psi. Same exact turbo but with a T04S and slightly lower displacement made 520whp at 24psi but with a T04S.
I would really like to see 600whp out of it but I dont think its possible.
art
art
We'll isn't that turbo efficient up to 30 something pounds? Also what's the diference between the S housing and the E housing? I was told with an E housing I could still use my intake pipe off my DRAG kit, where an S housing would be too big. If that's true, how much gain is there between the two?
crazyitr
Aug 2, 2003 05:48 PM
Full-Race Geoff
Dec 12, 2002 04:48 PM
