h23-turbo build up, need ur tips/tactics, info help secrets
Old Oct 4, 2003 | 01:37 AM
UltRaH22's Avatar
Default h23-turbo build up, need ur tips/tactics, info help secrets
gettin my h23 block soon, rod knock redoing the whole thing anyway... i need to know how big is too big to bore it and whats perfect. Im goin all out on it so let me know what is good and what is not. IM kinda new to Hseries so thats y im askin. Im lookin to go about 10:1 bored, sleeved, new bearings etc... also anyone with a boosted h23 thats built id like to see wat kinda #'s ur puttin down on the dyno.
Old Oct 4, 2003 | 10:20 AM
SKDRCR's Avatar
Default Re: h23-turbo build up, need ur tips/tactics, info help secrets (Option2 eg6)
I'm going to be doing the same thing too-------
might be better off in the FI forum
Old Oct 4, 2003 | 11:38 AM
PrecisionH23a's Avatar
Stock bore is 87mm and most of the H series shelf pistons are 20 over. Anything else is considered a custom piston and will run roughly $600. Darton sleeves can be bored out to accept a 89mm but that is kind of going overboard in my opinion.
Currently I am running a 88mm swain tech coated CP piston on my h23a with darton copper o-ringed sleeves and putting down 423whp @ 20psi.
Old Oct 4, 2003 | 12:38 PM
SKDRCR's Avatar
Default Re: h23-turbo build up, need ur tips/tactics, info help secrets (GudeH23a)
did you order your darton sleeves and then have them installed
at a machine shop or did you send the block to them
Old Oct 4, 2003 | 12:40 PM
Default Re: h23-turbo build up, need ur tips/tactics, info help secrets (SKDRCR)
I ordered my Darton sleeves from a company out in california and had a local machine shop install them locally (charleston, sc).
Old Oct 4, 2003 | 12:52 PM
SKDRCR's Avatar
koo, did the machine shop also micropolish your crank?
just curious because i'm thinking about sending
my block to golden eagle to get everything done
resleeved, mp the crank etc.
there's not that many good machine shops in kansas city
are you using hondata s200
Old Oct 4, 2003 | 12:56 PM
Yes i had the crank polished as well.
Make sure you send your cam-caps with your block when it is resleeved. Some people don't do that. When installing sleeves it is necessary for the MAIN BEARING caps to be fitting on after the sleeving process is done to make sure all of the tolerances did not change. I know another guy on the board did not send his cam caps in and all sorts of stuff was fubar.
I am currently running the hondata 4b. Next summer I will most likely upgrade to the s200 for the nitrous control feature.
Old Oct 4, 2003 | 01:02 PM
SKDRCR's Avatar
20psi+nitrous
you should put down some sick numbers
good luck
Old Oct 5, 2003 | 08:03 PM
UltRaH22's Avatar
anyone else?
what comp ratio are u runnin on that set up?
Old Oct 5, 2003 | 08:24 PM
Quiklude's Avatar
i have an built h23 block for sale, if you guys are looking for a project turbo block
its a h23a1 w/
GE sleeves 87.5mm
Crower Rods
ACL bearing w/ about 3k on them
balanced and micropolished crank
ARP head studs
ARP main studs
needs a hone and a new set of pistons, i had very bad luck w/ arias pistons (kept on beaking), im tired of turbo problems and im just going h22 n/a...just trying to save you h23 turbo guys some $$$ cause we all know how much rods cost for the h23
email: quiklude@comcast.net
aim: quiklude4ws
Old Oct 5, 2003 | 08:33 PM
prelittlelude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GudeH23a &raquo;</TD></TR><TR><TD CLASS="quote">I know another guy on the board did not send his cam caps in and all sorts of stuff was fubar.
anthony , did you main main caps? or did you really mean cam caps?, i know what you saying if you ment main caps, cuz they need to make sure everything is still in spec for the bottom end. but cam caps i dunno....
Old Oct 5, 2003 | 09:03 PM
Quiklude's Avatar
Default Re: h23-turbo build up, need ur tips/tactics, info help secrets (prelittlelude)
he means the main caps, and it is to check the line bore
Old Oct 6, 2003 | 09:17 AM
SKDRCR's Avatar
Default Re: h23-turbo build up, need ur tips/tactics, info help secrets (Quiklude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quiklude &raquo;</TD></TR><TR><TD CLASS="quote">i have an built h23 block for sale, if you guys are looking for a project turbo block
its a h23a1 w/
GE sleeves 87.5mm
Crower Rods
ARP head studs
ARP main studs
aim: quiklude4ws
you have mail
Old Oct 7, 2003 | 02:32 PM
UltRaH22's Avatar
what kinda comp ratio u running wit that 423 whp @ 20 psi.
Old Oct 7, 2003 | 07:46 PM
spoolinlude's Avatar
I live under a rock
Yeah he meant main caps..... which is sorta a give in, at least it should be, always send the mains with a block, even the hot tanks can thorw the tolerances off, I've seen it happen, its no big deal, they can just machine the cap seats or even bore the caps if necessary
Old Oct 7, 2003 | 09:20 PM
yes i meant main bearing caps, not cam caps, wtf was i thinking?
Old Oct 8, 2003 | 01:51 PM
I live under a rock
Got me, look at your avatar...... if you came home with that, first I'd slap you, then I'd think WTF was he thinking........ anyway i think you'll find that you really won't need 20pi+ AND nitrous..... you'll have enough fun getting 20psi to a good tune up
Old Oct 8, 2003 | 02:30 PM
UltRaH22's Avatar
GUDE h23: what compression are u running on ur set up to get 423whp? what kinda ft/lbs are u putting down as well?
Old Oct 8, 2003 | 04:40 PM
9.0:1 compression
360ft.lbs
Old Oct 8, 2003 | 06:29 PM
UltRaH22's Avatar
nice #'s im hoping to go with 9.5 or 10:1 with about that much boost.
Old Oct 8, 2003 | 07:41 PM
del_parker's Avatar
if you're still using that act xtss, it's gonna start slipping soon.
Old Oct 8, 2003 | 08:02 PM
Default Re: h23-turbo build up, need ur tips/tactics, info help secrets (del_parker)
Yea I figure the HA3-XTSS is not going to last forever. That will be replaced next summer, besides I am only running around 330whp on the street daily.
Good news... I will have some nice stage 3 gator axles hopefully next week
Old Oct 8, 2003 | 08:13 PM
SKDRCR's Avatar
i wonder if xes ever found some axles to handle
the power of that beast
Old Oct 8, 2003 | 08:18 PM
I live under a rock
Yeah he did, some customs jobs from up north
Old Oct 8, 2003 | 08:30 PM
IloveNewt's Avatar
How much u want for the block? Thinkin of maybe gettin a backup block.(maybe after i refinance hah jk)
I had 9:1 je's runnin in some ge sleeves with a t3/t4b and made 311whp@1bar. But this was on pump, with leaking HG from ARP studs bein stretched, blown pistons, balancer shafts off.
I will be trying Venolia Pistons @ 8.8:1, tryin to get my turbo a little more into its max efficiency range.
PreludeZ
Jan 6, 2006 10:19 AM
HumanH23
Oct 30, 2004 03:52 PM
ludesleep
Apr 3, 2003 10:56 AM
noslude93
Mar 14, 2003 05:01 AM
BoostedH23a1
Feb 1, 2003 04:16 PM
