FS: Apex'i Autotimer - Pen Style - BRAND NEW [PICS]
Old Oct 3, 2003 | 05:41 PM
B2FiNiTY's Avatar
Default FS: Apex'i Autotimer - Pen Style - BRAND NEW [PICS]
Brand New in box! It can be used for Turbo or N/A! I was going to use for N/A but didn't want to be a ricer
Taken directly from Apexi-usa.com:
"The Apex Auto Timer allows the vehicle to idle for a preset amount of time after the ignition key has been removed. In turbocharged vehicles this prevents hot oil in the engine from coking up in the lines. Hard driving can raise engine oil temperatures to dangerously high levels. Proper cool down is essential for a healthy turbo and engine. In normally aspirated cars, the Auto Timer can also be used to warm/cool the inside of the car without having to sit inside. The Auto Timer stands as a technological marvel. The pen shaped, compact size makes the Auto Timer one of the smallest turbo timers on the market. This allows a clean and stylish installation virtually anywhere inside the car. The unique multi angle joystick button allows easy navigation through the many feature menus. Upgraded in every way from the previous model, the new Auto Timer can automatically determine the necessary amount of after idling time. A Manual Mode allows the user to preset desired idling times from 0 sec.~10 minutes in 16 increments. By inputting O2 sensor voltage, the Timer can also display theoretical air fuel ratio. Since the Auto Timer uses the factory O2 sensor which is primarily designed for emissions, the readings may not be as accurate when the O2 sensor is cold. A'PEX recommends that the O2 sensor readings be compared to a high grade "tuning" O2 sensor for comparison. The Timer can also display critical data such as O2 sensor voltage and Battery Voltage. To prevent potential theft while running, the handbrake safety feature shuts off the vehicle when the handbrake is released without the ignition key."
$90 SHIPPED
Located in Southern California. Pick up is an available option.
Payment:[*]Paypal (with fee)[*]Money Order[*]Personal Check (7 days to clear)
Feel free to PM or email me at ngm_83@hotmail.com- Thanks.
Thanks to WTDR for the generous free hosting.
Old Oct 3, 2003 | 06:13 PM
BuiltB18C1
Guest
Posts: n/a
pm sent
Old Oct 3, 2003 | 06:15 PM
B2FiNiTY's Avatar
Default Re: (BuiltB18C1)
You have IM back
Old Oct 3, 2003 | 09:43 PM
BuiltB18C1
Guest
Posts: n/a
Default Re: (B2FiNiTY)
thanks!
Modified by BuiltB18C1 at 8:38 AM 10/4/2003
Old Oct 4, 2003 | 11:13 AM
B2FiNiTY's Avatar
Still available!
Old Oct 6, 2003 | 03:19 PM
kHoA DoGG's Avatar
hey there mr. b2infinity. How much for pick up? Are you still in riverside?
Old Oct 6, 2003 | 05:23 PM
B2FiNiTY's Avatar
Default Re: (sNoOziN' EF8)
You have IM
Old Oct 7, 2003 | 10:22 AM
^jefs0ng's Avatar
Banned
So this is like a turbo timer..? Does it have a set time or do you set it or do does it automatically find out?
Old Oct 7, 2003 | 11:49 AM
B2FiNiTY's Avatar
Default Re: (jsxtek)
It is basically a turbo timer. You can have it autoset or set your own time.
"Upgraded in every way from the previous model, the new Auto Timer can automatically determine the necessary amount of after idling time. A Manual Mode allows the user to preset desired idling times from 0 sec.~10 minutes in 16 increments. "
Old Oct 7, 2003 | 05:24 PM
^jefs0ng's Avatar
Banned
Man I want one..
Old Oct 7, 2003 | 05:37 PM
The Destroyer's Avatar
Im not sure if its the same thing, but if it is your crazy.
http://www.needboost.com/pages...imers Need boost sells a apexi turbotimes like yours for 27 buckaroo's.
Old Oct 7, 2003 | 05:39 PM
kHoA DoGG's Avatar
Default Re: (I Need Money.)
actually if you read closer, the harness is $27 the TT is actually $107.
Old Oct 8, 2003 | 10:06 AM
B2FiNiTY's Avatar
Thanks for the overpriced ad, makes me look better Just kidding.
Old Oct 8, 2003 | 02:09 PM
Sry man, my apollogies, my apollogies.
GOOD SELL! lol.
Old Oct 8, 2003 | 06:40 PM
B2FiNiTY's Avatar
Still available! If no one buys at the end of the month, it will be put on my n/a car
Old Oct 9, 2003 | 06:54 PM
Jspectyper's Avatar
lowest you can go shipped to me? I've bought from you before.
Old Oct 9, 2003 | 07:15 PM
B2FiNiTY's Avatar
Default Re: (Jspectyper)
You have IM
Old Oct 22, 2003 | 12:00 PM
B2FiNiTY's Avatar
Bump
panama_b18c1
May 2, 2007 03:37 PM
Fu_kJDM
Apr 17, 2006 11:41 PM
Pfieff
Feb 26, 2005 07:18 AM
DarkBB4
Aug 15, 2004 07:28 AM
99B16Si
Jul 20, 2004 07:14 PM
