heeelp, H22A engine block
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raser5050 »</TD></TR><TR><TD CLASS="quote">to the top in block H22À into the oiled channel of inheres the oiled sprayer, for which it, which can it will happen if 4 it it did not establish???
So are you asking if it's a problem if you do not install the piston oil squirters?
Number 23 in the diagram?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raser5050 »</TD></TR><TR><TD CLASS="quote">oooo no,I have vtec
Yea, you might have VTEC but probably arent getting any oil to the squirters. So basically, you have a H23/VTEC hybrid now and it will blow soon if you keep redlining it.
</TD></TR></TABLE>Yea, you might have VTEC but probably arent getting any oil to the squirters. So basically, you have a H23/VTEC hybrid now and it will blow soon if you keep redlining it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4bidden »</TD></TR><TR><TD CLASS="quote">
Jeremy what is number #21 though? He has the squirters..I think. Is 21 for VTEC oiling? I have no Idea.
</TD></TR></TABLE>Jeremy what is number #21 though? He has the squirters..I think. Is 21 for VTEC oiling? I have no Idea.
So you did not install this
Okay that is the Oil Control Orifice, and should NOT be installed for the H22A engine. so if it's an H22a head then you did the right thing by not putting it in. It's only there for the H23a, F22b, and f22a engines.
58psi is normal isn't it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greyout »</TD></TR><TR><TD CLASS="quote">manual says it should be above 9 psi at idle and above 50 psi at 3,000 RPM.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rasser5050 »</TD></TR><TR><TD CLASS="quote">how much this will bar??
over .62 bar at idle and over 3.45 bar over 3000 rpms. It shouldn't be going higher than 5.5 bar that's too high
</TD></TR></TABLE>over .62 bar at idle and over 3.45 bar over 3000 rpms. It shouldn't be going higher than 5.5 bar that's too high
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93preludevtec »</TD></TR><TR><TD CLASS="quote">wow, after reading that thread joel should definetly be added as a moderator</TD></TR></TABLE>
:bows:
thanks, I knew he knew what he was talking about, it was just a language gap. I am helping him in the ecu chip thread as well.
I'm hoping he will repay me by sending me Anna Kournikova as a mail order bride.
:bows:
JBirch_97Prelude
Feb 26, 2007 01:43 PM
but
May 7, 2006 02:43 PM
sitinthehall
Jul 30, 2005 01:44 PM
