ARC intake
Old Aug 27, 2001 | 08:41 PM
Superman's Avatar
New User
Default ARC intake
Can someone who understands the ARC intake explain to me how it performs better than most of the other intakes out in the market? I understand that it does suck in hot air rather than cold air like the stock setup or an AEM CAI. Is it because it sucks in so much more air that it's ok even though it's sucking in more hot air than other CAI?
Old Aug 27, 2001 | 10:51 PM
AJ PwR's Avatar
Default Re: ARC intake (Superman)
ARC air box is designed to have the maxium volume for the box for best ON/OFF throttle response. You won't expect big increase in hp. There are ppl who runs them on the track.
Old Aug 28, 2001 | 04:42 AM
Superman's Avatar
New User
Default Re: ARC intake (AJ PwR)
Are you suggesting that other than immediate throttle response, most other aftermarket intake would outperform it horsepower wise?
I do remember someone here who said that it outperformed the AEM CAI in the horsepower department on the dyno.
BTW, is $570 USD a good price? Thanks.
Old Aug 28, 2001 | 04:48 AM
Kengs's Avatar
I don't think anybody has dynoed the ARC against the AEM. I will dyno my setup when my Toda As arrive, but it is only a low-rent Si with the B16.
$570 for the Induction Box AND the Intake Chamber is a good price.
Old Aug 28, 2001 | 09:23 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: ARC intake (kengs)
if i ever get my *** in gear, and get to the dyno i will have a before run with aem cai, spec b's etc. i will redyno after i get the ARC. i am going to do the impossible and mod a ek ARC box and install it in my eg. wish me luck....
Old Aug 28, 2001 | 09:51 AM
Cosworth's Avatar
Default Re: ARC intake (rodney)
Shane - have you ever baselined your car? I want to see how many ponies you put down w/ your bolt-on mods. At the dyno this past weekend, an Si w/ bolton's, aem cai, dc header, apex'i N1 exhaust put down 148hp to the wheel. I'm sure you're probably near there or a few ponies above.
Old Aug 29, 2001 | 01:01 PM
AJ PwR's Avatar
Yes!!! These inatke system works good with big cams. This intake smoothen the vtec changeover, it tries to elimate the power dip.
Old Aug 29, 2001 | 01:03 PM
Cosworth's Avatar
Alan - do you have a dyno of ARC?
Old Aug 29, 2001 | 01:42 PM
1GreyTeg's Avatar
Just name the day Rodney and lets go!
You know I wanna dyno too. Of course the day has to fit into my hectic schedule but, in 2 weeks all is slow again and lots of free time to Dyno and race!!!
A.
Old Aug 29, 2001 | 11:49 PM
AJ PwR's Avatar
Default Re: ARC intake (Cosworth)
hehe I am not Alan. I am Ben!!!!
I used to have it when still have my stock B18CR motor and I ran 14 flat 1/4 mile.
Old Aug 30, 2001 | 05:48 AM
Cosworth's Avatar
Sorry, Ben. Three times that I called you guys, it was Alan answering and taking my orders.
BTW, 14sec flat w/ just ARC intake? What else did you do to it on that run?
Old Aug 30, 2001 | 07:17 PM
AJ PwR's Avatar
It was a while back ago and here are the stuff that I used to have in my civic:
Spoon B18C balanced/blueprinted engine
Spoon camgears
Spoon 4-2-1 header (older version)
Spoon clutch
Spoon flywheel
Spoon ECU
Spoon test pipe
ARC Intake system
JDM 5zigen exhaust system
It works pretty good by that time. However, I change my setup now so I am running with differents parts I always like to test different parts myself.
Old Aug 30, 2001 | 07:26 PM
ITR111's Avatar
New User
a bit OT, I want to know anyone using ARC titan exhaust here?? How well it does compare to amuse or M&M??
Old Aug 30, 2001 | 07:41 PM
Kengs's Avatar
Spoon camgears
Spoon clutch
Spoon flywheel
Spoon ECU
Spoon test pipe
ARC Intake system
Ben,
I don't think that qualifies as a stock B18C motor - no offense.
accord03
Aug 23, 2008 11:05 AM
Import Prelude
Apr 6, 2007 04:04 AM
hOOch
Nov 18, 2002 09:27 PM
Tony the Tiger
Feb 26, 2002 11:14 PM
gmsu00
Oct 5, 2001 09:23 AM
