B20Z stock bottom end w/ PR3-4 head and CTR cams??? Did search, no answers
Will this setup work or will the pistons kiss the valves? Also, would this be a descent motor or should I build the bottom end first? i.e. how much better than a OBD1 B16A would it be?
I always went about my projects and builds with the saying...
Do it right the first time so there is ONLY a first time
81mm bore pistons wont fit in a 84mm bore b20 block...go with ls vtec if you wanna use b series pistons.
im sorry thats my bad, i was kinda drunk last night and i read ctr cams as ctr pistons for some reason.
Driven
14
Apr 4, 2004 10:58 PM
