When to replace throwout bearing?
Why dog eat his crap?
As long as you are inside the mission it is better to change the rerease bearing. If it is a bad then it will not turn fleely it may be difficult to turn the bearing. If you are not changing the crutch disc or cover or frywheel and you think it is better to change soon then you should wait to change everything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PacMan ITR »</TD></TR><TR><TD CLASS="quote">what you got up your sleeve this time dennis, i know you arent dropping the tranny just for the throwout bearing.
It's Dennis, he'll find any reason to do anything to his car.
Dennis - "Uh oh, water is dripping from my car, I should take out the AC!"
</TD></TR></TABLE>It's Dennis, he'll find any reason to do anything to his car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR 599 »</TD></TR><TR><TD CLASS="quote">
Dennis - "Uh oh, water is dripping from my car, I should take out the AC!"</TD></TR></TABLE>
Treat your car well and your car will treat you well as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">Treat your car well and your car will treat you well as well.</TD></TR></TABLE>
..and then the cops come.
Replace it when you replace your clutch, PP, resurfaced flywheel, and pilot bearing.
I wouldn't go in to replace just a TO bearing. It's too big of a PITA. I know from personal experience, I've had my transmission out twice in the last 10 months!
And are you sure something is wrong with your TO bearing? I thought mine was bad too and replaced it with my clutch only to find out the noise was coming from my input shaft bearing (when clutch was out) not the TO bearing (when clutch was in).
The second removal was to get the tranny rebuilt (actually just the input shaft bearings replaced).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">When should I replace it? Any other things while dropping the tranny?
Edit: Can't afford clutch/flywheel combo yet. </TD></TR></TABLE>
That's not your TO bearing making the noise. I just went through this. It's the Input shaft bearing (inside the transmission).
TO bearing is bad when you depress the clutch and it makes noise.
Input shaft bearing when the clutch is released (out) and it makes noise.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dk127 »</TD></TR><TR><TD CLASS="quote">When it starts making noises when you drive.... Or, mine makes a slight noise when I'm at idle, with my foot off the clutch. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typer_801 »</TD></TR><TR><TD CLASS="quote">That's not your TO bearing making the noise. I just went through this. It's the Input shaft bearing (inside the transmission).
sounds right to me.
sounds right to me.
****. My tranny makes noise when idling off the clutch, and when I put it in, noise goes away. Kind of a jingly sort of noise. Same thing?
Guess this is a good excuse to save up for a JDM FD?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00 FBP ItR »</TD></TR><TR><TD CLASS="quote">Rear main seal wouldn't hurt.. how many miles?
"If it ain't broken, don't fix it"
</TD></TR></TABLE>I REALLY agree. Give this man a beer
spidermancivic
Sep 25, 2004 04:44 PM
