Help my turbo integra....did search but i dont think it matches mine
Old Oct 2, 2003 | 04:31 PM
Rod.'s Avatar
Default Help my turbo integra....did search but i dont think it matches mine
After puttin on my turbo 1wk 1/2 ago..my stock clutch goes out i couldnt even shift into gear at any stop lights. I would have to turn the car off and it shifts perfectly in gear. What could be the problem(is it the clutch like i think)??? Also when i rev up in neutral the rpm go up then come down real low to about 400-500 rpm to it feel like it about to die then goes to regular idea at 900. What could that problem be?
Old Oct 2, 2003 | 05:21 PM
grndcont's Avatar
if you need it i have a used centerforce dual-friction clutch laying around. $50 shipped.
Old Oct 2, 2003 | 05:26 PM
bigwig's Avatar
you probably killed your clutch...just a guess but i know that integra fucked up on the LS...have yuo ever noticed when you are parked...and you start your car...clutch and brake down and go to get in reverse you cant...but you lift up your foot...and put it back down on the clutch and it goes in fine....yea...i think you killed your clutch+integra clutches are mildly retarded.
Old Oct 2, 2003 | 05:29 PM
bottlefedb18c1's Avatar
i had a problem where the spring broke in my clutch and i can disegage it but i had a very hard time shifting when moveing or getting into gear
it was hanging up i put a new act in and it was mint
Old Oct 2, 2003 | 06:08 PM
Rod.'s Avatar
Since the clutch is out now...why when reving my rpms drop down to almost killing the car then it will go back to regular idle?? That is my second problem
Old Oct 2, 2003 | 06:18 PM
ReeH!'s Avatar
man the answer to your second problem, when my car did that my rings and pistons were going bad, look and see if there is smoke coming out throught your valve cover breather
u should do a compression check, it might not be it but thats what it was in my car the best thing to do is check the compression
Old Oct 3, 2003 | 01:41 AM
Rod.'s Avatar
No smoke coming through my valve cover. I dunno if 147,000 miles on the motor will do it? I bought the car bone stock. It is like the rpm drop kind of fast like i have a lighten flywheel but i know i dont. Could this rpm drop be hurting my car?
Old Oct 4, 2003 | 03:12 PM
i had 180,000 miles on my old 95 gsr with a turbo kit for 60,000 miles and never blow by problems
LS_VTECteggy
Dec 21, 2009 05:22 AM
CrazyModGSR
Sep 7, 2004 03:53 AM
alfaaay
Mar 31, 2003 11:57 AM
Sam
Oct 9, 2002 03:12 PM
asianspeed
Aug 10, 2002 12:00 AM
