ATS gear set and final drive
Is anyone running the 1,3,4,5 gear set and 4.92 final drive from ATS?? just wondering how you like it.. i have it and want to put it in!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg »</TD></TR><TR><TD CLASS="quote">You have the gearset AND final drive?
Wondering what you plan to do with a car equipped with such gearing?</TD></TR></TABLE>
Race it i hope
. Not gonna be goin much faster than 120.Correct me if im wrong.
Race it i hope
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMITR222 »</TD></TR><TR><TD CLASS="quote">
Race it i hope
. Not gonna be goin much faster than 120.Correct me if im wrong.</TD></TR></TABLE>
113.4 MPH @ 8400 RPM on 23.1" diameter tires (which are 205/50/15's) to be a bit more exact.
For autocross, could be interesting depending on motor setup.
For Roadcourse, I can't think it would be worth it, and the top speed in each gear, especially 5th would limit it a bit too much.
Race it i hope
. Not gonna be goin much faster than 120.Correct me if im wrong.</TD></TR></TABLE>113.4 MPH @ 8400 RPM on 23.1" diameter tires (which are 205/50/15's) to be a bit more exact.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR »</TD></TR><TR><TD CLASS="quote">waiting for christian to pop in
Pop in, or Lay in?
</TD></TR></TABLE>Pop in, or Lay in?
car is a daily driver.. occasionally take it for club events.. we have the gear set and fianl drive to test for our magazine.. has any one ran the gear set with the stock final drive???
ken (black r) or black rocker or wutever has it or is going to be running it
i think its over kill
at least get the jdm fd
you will prolly loose time in an autocross from having to shift soo much
if its free, then why not. unless you are launching at 2.5k and have sticky tires, kiss first and 2nd gear good bye if you have decent amount of power
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zentraedityper »</TD></TR><TR><TD CLASS="quote">Is anyone running the 1,3,4,5 gear set and 4.92 final drive from ATS?? just wondering how you like it.. i have it and want to put it in!!!!</TD></TR></TABLE>
hey bro, it'll be too friggin short. ken (black R) is doing it, and he is out of his mind. look for a f/s post after he drives it the first time...
i suggest either one or the othr. what are your mods? intended use?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zentraedityper »</TD></TR><TR><TD CLASS="quote">we have the gear set and fianl drive to test for our magazine.. </TD></TR></TABLE>
Which magazine if I may ask?
And, just out of curiosity, how did you stumble upon or decide to do the ATS FD/gears? Did you guys research a bit on the gear ratios before you dropped that chunk of change, or,,,?
Modified by 1GreyTeg at 9:27 AM 10/3/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HYREV2NR »</TD></TR><TR><TD CLASS="quote">With all that low gearing I bet it'll run a smokin' 1/8 mile & some awsome 60 foot times. Mercy!!!</TD></TR></TABLE>
i don't think he'll get a good 60 foot as he'll probably have to shift 3 times....
yea thats why i am qustioning installing the gear set and final drive.. i dont know how i am going to like it on a daily basis.. but i do have to rebuild my tranny.. so i dont know what to do.. the magazine i work for is DRAG Sport and Tuner Performance Reports. We did a gearing your b-series article a couple months ago... go to http://www.dragsport.com
Let me get this straight. Your magazine wrote an article called "GET 'N GEAR
CHOOSING THE BEST GEARS FOR MAX PERFORMANCE " and you didn't even test out the products?? I don't understand. Please don't take this as rudeness, I am just confused about this. (and no, I didn't read the article...enlighten me as to its contents)
we have a computer program where we enter in your cars specific dyno graph (in this case my itr and my friends turbo gsr EK), and you then can change the settings for each gear, final drive, wieght, etc... we had a lot of different combinations and it would be impossible for us to test each one... so the computer program lets us see how well it performs in the quater mile... the ATS gear set with a 5.0 fd was the best.. but we opted to use all ATS products for a comparision to our computer program...
DRAG Sport issue #9.. check it out.. the computer program is really accurate too..
I drove my buddy's car with the whole ATS setup Clutch, gears and LSD w/ 4.9. 2nd gear is like 1st gear. I would go 4.7 with the ATS gears if you drive daily.
Robbie...as an FYI, running stock USDM 1-5, and the JDM 4.785 at Buttonwillow, Race#14 CCW I was hitting speeds of ~125mph on the dog leg, and Big Willow coming into #8 I was ~127mph...so you should be hitting the rev limiter in 5th gear unless you install a higher rev limiter(although I know that you already have this). These speeds were indicated on the speedometer, so who knows what the actual speeds were.
Austin
Austin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperTwinz »</TD></TR><TR><TD CLASS="quote">I drove my buddy's car with the whole ATS setup Clutch, gears and LSD w/ 4.9. 2nd gear is like 1st gear. I would go 4.7 with the ATS gears if you drive daily.</TD></TR></TABLE>
If this is the hatch back that Lawrence had at the dyno a few weeks ago I can attest that that thing had the shortest gearing I have ever seen.
Austin
Austin
.....what he said on the daily thing.
Spoon also has an interesting gearset - kind of like a cross between the ATS and Quaife:
http://www.aj-racing.com/spoon....html
Pop in, or Lay in?
</TD></TR></TABLE>I am not sure what Lay In means but I'll add a lil something to this thread.
The ATS 1,3,4 and 5th gear set is really really nice. I really love it with the stock FD.
But with the 4.9 or 4.7 FD I feel it maybe a little over kill. Even with a raised rev limit you are bound to run out of gearing on a road course and as far as for Autocross I have no clue how it would benifit you.
Pop in, or Lay in?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Christian »</TD></TR><TR><TD CLASS="quote">I am not sure what Lay In means but I'll add a lil something to this thread.
For God's sakes, this was 2 months ago, I can't remember what I had for breakfast this morning.
But, your information was what I expected regardless.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1guy »</TD></TR><TR><TD CLASS="quote">whats the price to install the ats final gear?
thanxs
blake </TD></TR></TABLE>
Depends on where you are geographically (local going rates) or if you have freinds like D and the we todd's who'll just do it all for you for free. Mine cost about $400. I believe and also included installing a LW FW.
thanxs
