Recommendations for ls/vtec block
Old Oct 2, 2003 | 04:18 PM
SupaFly_Honda's Avatar
Default Recommendations for ls/vtec block
okay, I'm already running a b16 head with sk2 stage 2 cams and valve springs and retainers. Can someone give me a good rod and piston setup for my ls block? I just want something that I can put in easily without any machining work.
Old Oct 3, 2003 | 01:40 PM
Nutzurchin's Avatar
i got a block for sale if u r intereseted.
https://honda-tech.com/zerothread?id=636739
Old Oct 3, 2003 | 01:45 PM
King Tut33's Avatar
Default Re: (nutzurchin)
Stock LS rods with B16a PR3 pistons. You can throw in some ARP rod bolts for good measure.
Old Oct 3, 2003 | 02:37 PM
Default Re: (King Tut33)
tut33, what will my cr be? also, is oem ls headgasket okay, or upgrade?
Old Oct 3, 2003 | 04:00 PM
skribblah's Avatar
Default Re: (SupaFly_Honda)
ls headgasket = ok, but modify it:
compression with JDM b16 pistons would be 11.309:1
compression with USDM b16 pistons would be 11.1009:1
Old Oct 3, 2003 | 05:45 PM
jumpmann23's Avatar
From: Your really lame if you dock my points, WA, 98033
Default Re: (skribblah)
i didnt modify my headgasket. i think that picture is for if you want to relocate the dowel pins instead of just enlarging the holes. either way it works.
Boosted_90Teg
Jun 23, 2011 04:25 PM
gsteg91
Jan 17, 2008 04:13 PM
92eg6lsvtec
Jul 22, 2005 12:11 PM
joey1320
Dec 7, 2004 09:10 AM
BrtOtCRX91
Aug 15, 2004 02:05 PM
