Car smoking at redline....What is it??
Old Oct 2, 2003 | 12:55 PM
civicqm's Avatar
Default Car smoking at redline....What is it??
I was wondering if anyone here can help me. I am sure that their is someone who can. So here is the deal. I have a b18C1 in my 92 hatch and everytime I take the car to redline (8k) and let off to shift I get a puff of white smoke out the back. The car is running fine and has no misses or knocks. I also am running a Skunk2 racing ecu, Skunk2 exhaust and intake. Anyone have any ideas or things I can check to see what the cause of the problem may be? Any help would be greatly apperciated. Thanks
Old Oct 2, 2003 | 01:05 PM
turbociv's Avatar
after a full throttle run up to red line you stir alot of oil up and then when you let off the gas in between shifts vacuum is at its highest and is sucking the oil through your valve seats. My suggestion is valve seals. On the other hand that ecu can be running you really rich at certain rpm incraments and you might be seeing unburnt fuel. Worst case sinareo if the motor is smoking during excelleration than oil control rings.
Old Oct 2, 2003 | 01:06 PM
cr00klyn718's Avatar
Default Re: Car smoking at redline....What is it?? (civicqm)
Probably running rich... same thing happens to me ... im running skunk2 p28,skunk2 mani,dc 4-1,exhaust... just got a compressing and it was straight all they way across the board and leakdown was only at 3% on all cyl... so my guess we running rich on the skunke proggy....but still get a compression or leakdown test... its good to know how the motors doing
Old Oct 2, 2003 | 01:09 PM
civicqm's Avatar
Default Re: Car smoking at redline....What is it?? (cr00klyn718)
The car is using oil tho, that is what concerns me and it is white smoke. Wouldn't fuel be black?
Old Oct 2, 2003 | 01:33 PM
yeah mines is not per-say white smoke... it has some black in it.....but not like dark smoky black...lol kinda hard to explain.
Old Oct 2, 2003 | 01:34 PM
snowseeker's Avatar
Fuel is a grayish to black smoke, white is antifreeze. Oil is blue smoke.
I would still be leaning tward the rich side though in your case. Mine does it to at the track.
Does it look like this smoke?
http://www.wisconsinstreetdomi...3.mpg
Old Oct 2, 2003 | 03:34 PM
deez nuts's Avatar
Default Re: Car smoking at redline....What is it?? (snowseeker)
i think it's your piston rings.... mines had white smoke at high rev and it was because of my rings. thats when i run it hard
Modified by ek4 fa sho at 4:33 AM 10/4/2003
koumatae
16
Apr 9, 2013 07:41 PM
ic108
Apr 16, 2008 05:07 AM
jd-em
Dec 6, 2007 12:57 PM
Liquidgsr
Jan 10, 2006 02:31 PM
91glassycrx
Feb 22, 2004 01:38 AM
