New style carbon fiber rear diffuser 56K Beware!
Thought you guys might like to see this. Should fit the EP3
Installed
Whether you drive your car to and from work or only drive a quarter mile at a time you will see remarkable benefits with our new diffuser design. At speed a rear bumper cover can increase overall aero drag and promote lift. Neither of these effects are desirable on any vehicle, and as speed increases the problem becomes more pronounced. Think of your rear bumper as a big air brake. Our diffuser removes the trapped air and lets it flow freely through the bumper cover. Our product promotes higher track speed and gives the driver more stability at those high speeds.
This product has been tested at the drag strip on a 9 second, 150mph drag Civic. The diffuser is water jet cut from our high quality Rigid RacePlate, and it has the same glossy finish everyone loves. It measures approximately 4"x44.5", and comes with easy to read instructions for trouble free install. For those really fast racers out there you will be happy to know we machined a center hole just for your parachute tube. A secondary benefit for some cars using parachutes is faster parachute deployment due to the larger volume of air exiting out the bumper cover.
They are $125
Installed
They are $125
crx12
Performance
14
Nov 19, 2008 12:32 PM
crx12
22
Oct 3, 2003 05:28 AM
