D16A6 catch can questions...
Old Oct 2, 2003 | 07:27 AM
xci_ed6's Avatar
Default D16A6 catch can questions...
I did a search, so no bugging me about that.
I want a catch can on the PCV system and one on the valve cover breather, if they both used same can (so only one total) that would be ideal. I don't want any filters that vent into the engine compartment if possable, I like it to stay clean in there (oil film + gravel roads = bitch).
I am looking for ideas on where to get a can, but most importantly how to hook it up.
-Dustin
Old Oct 2, 2003 | 08:00 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: D16A6 catch can questions... (krustindumm)
a catchcan in the line from the valve cover will do nothing on a NA car. the PCV line can use an oil separator though, do a search on catch can in tech there are a few posts with links and diagrams on a very nice st up using moroso can and a ford PCV....
here to save you some trouble.
Stan
Old Oct 2, 2003 | 09:01 AM
xci_ed6's Avatar
Default Re: D16A6 catch can questions... (90crxsi)
Thanks, on my turbo car I threw alot of oil out the valve cover, I thought it might be the same way with the non-turbo.
With that setup, should I remove the oil seperator on the back of the block?
-Dustin
Old Oct 2, 2003 | 09:15 AM
that is a good questions indeed :-)
i would say keep it.
Stan
slowassBubble
Jul 25, 2012 06:30 PM
TravisBiggie
Jun 27, 2012 11:52 AM
kreatekustomz
May 21, 2010 09:11 PM
nerdsports
May 10, 2003 11:47 AM
