someone help please
ok.......93 integra LS.........what should i do to make it relatively quick i dont need a 12 or even a 13 sec. car just hittin low 14's if fine by me ................and i dont want to spend thousanda upon thousands of dollars................so should i swap if so what to??? should i turbo if so what setup?? should i build if what do i need to get??? or the ever popular LS Vtec?? i just need lots of opinons and some help on how to spend the money i got ok thanks guys
if you don't want to spends thousands upon thousands then don't build an LS/VTEC because to build it right its gonna cost you. i would swap a b18c1 into the car personally. you're already at obd1 so all the emissions equipment is already there, just basically a drop in job. except for the hydro tranny you can either run lines or find a b16 cable tranny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic_EX »</TD></TR><TR><TD CLASS="quote">B18c1
some minor mods and you should hit 14s easy.</TD></TR></TABLE>
no need, 40 shot of giggle gas, and some nice tirez well do it, just semi gut the car.... all that and under 500
deestah3
Apr 5, 2007 01:01 PM
