iceman 2 piece cai is disconnecting! help!
anyone have a 2 piece cai by iceman? my cold air extension (the part that extends through the hole and collects the cold air) keeps disconnecting randomly from the short ram, although i tighten every hose securly, wut can i do? is it coz the hole where the resonator used to be, is just too tight? help??!?!?!
You may have crappy engine mounts and everytime you get on it you
will get a lot of engine movement. You could undo the bracket that
mounts the Iceman and run the car for a couple days. To see if it
does not fall off as much. Tighten those clamps really good too.
Oh, get some Energy Suspension mount inserts.
They are relatively easy to install and they're cheap. (Versus stock mount replacement)
b16ek4
Jun 25, 2005 10:35 AM
