B20 Fuel Pressure
Old Aug 27, 2001 | 12:02 PM
Muglit's Avatar
New User
Default B20 Fuel Pressure
Could someone please give me an idea of what I should set my B&M FPR to. I have a b20 w/ls manifold, I/H/E, and a test pipe. I'm using a '95 ls ecu. HX guy your input would be especially apreciated since you have a b20 and have been to a dyno.
Old Aug 27, 2001 | 12:09 PM
HX_Guy's Avatar
Default Re: B20 Fuel Pressure (Muglit)
Are you using a regluar intake or cold air?
i have not tested a regular short intake...but with the 3" diameter cold air setup...around 44 PSI (w/hose attached) was what seemed to work best.
Check it out:
See how it picked up quite a bit in teh midrange with more fuel? Again though..this might be because of the cold air intake sucking in extra air at 4500.
Old Aug 27, 2001 | 12:21 PM
Muglit's Avatar
New User
Thanks
Yeah its a cold-air, Injen Intake w/cold-air extension, I'm pretty sure it is 3" also.
Old Aug 27, 2001 | 12:26 PM
HX_Guy's Avatar
Heh...sweet. I have the DC Sports intake with Injen Cold Air Extension...so basically the same thing as yours. Try around 42-44 PSI w/ hose attached.
Old Aug 27, 2001 | 12:27 PM
H23 Power's Avatar
hey, OT from this post...but what was that dip in power from???
Old Aug 27, 2001 | 12:32 PM
HX_Guy's Avatar
Default Re: B20 Fuel Pressure (01GSR)
What dip in power? It isnt actually a dip in power...
Youre looking at it kidna like "The glass is half empty" instead of "the glass is half full"
The "surge" at around 4500 is a characteristic of the cold air intake...if you were to use a regular intake...the power would just be linear (or so Im assuming...Ill check this next time I hit the dyno)
Old Aug 27, 2001 | 01:39 PM
H23 Power's Avatar
Default Re: B20 Fuel Pressure (HX_Guy)
thats a rather large spike for just an intake...there looks to be something happening...the torque curve should be rather flat...
Old Aug 7, 2008 | 06:41 AM
gabebauman's Avatar
Default Re: B20 Fuel Pressure (H23 Power)
Back from the WAY dead...sorry.
I installed the fuel pressure gauge to check what pressure I'm at before I installed the adjustable fpr and I believe my fuel pressure is way low.
26 psi? This is while the car was running. Shouldn't I be around 45 psi?
I'm using stock 240cc injectors with what I believe is an LS fuel rail on a B20Z2 motor in my '98 Civic Ex.
Old Aug 7, 2008 | 08:40 AM
ivan93egreppin210's Avatar
Default Re: B20 Fuel Pressure (gabebauman)
im at 45 on my b20z2 using an obd1 p75 ecu. how does it run?
Old Aug 7, 2008 | 08:42 AM
gabebauman's Avatar
Default Re: B20 Fuel Pressure (ivan93egreppin210)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ivan93egreppin210 &raquo;</TD></TR><TR><TD CLASS="quote">im at 45 on my b20z2 using an obd1 p75 ecu. how does it run? </TD></TR></TABLE>
It runs good...just has a rpm surge at idle. I too am using a stock P75 ecu.
Old Aug 7, 2008 | 10:01 AM
gabebauman's Avatar
Fuel pressure reads 32psi with the vacuum hose disconnected at idle. I'm gonna throw the fpr on tonight and get it up to 45psi.
Old May 14, 2009 | 04:50 PM
im done's Avatar
Back up from the dead. I just did a JDM B20B in a 99 automatic integra. Everything is fine but check engine light went on because it was running lean. I reset it and drove it for about 100 miles and the check engine light didn't go on. How many psi should i set the fuel? BTW, everything is stock.
Old May 19, 2013 | 09:07 AM
MR AZEEZ's Avatar
HELLO GUYS, I AM BUILDING A STD B20 VTEC I CANT SEEM TO FIND A B20Z1 BLOCK SO IM GOING B20B, STOCK BOTTOM END NTN CHANGE WITH A VTEC HEAD WHICH IS PORTED AND GAS FLOWED STD INJECTION SYSTEM... WILL THE STD VTEC FPR AND ECU RUN THE CAR? ITS A 00' CIVIC VTEC... SO I WOULD LIKE TO KNOW WHAT I SHOULD DO, I AM GETTING AN ADJUSTABLE FUEL PRESSURE REGULATOR WITH A GAUGE SOME1 SET IT AT 4 BARS... ANY ADVICE I WILL CHIP THE CAR AS I GATHER MORE CASH, PUTTING UNI CHIP Q+
Old May 19, 2013 | 09:11 AM
B_Swapped93's Avatar
you realize this thread is 5 years old right...why all caps ? start a new thread nothing stopping you from it
Old May 19, 2013 | 11:43 AM
SlowB20z's Avatar
Mine was just like that, like 29psi- got me a blox regulator turned up to 50psi problem solved
Old Jun 4, 2013 | 07:43 AM
MR AZEEZ's Avatar
THE REASON I DID THIS IS BECAUSE ITS NOT LETTING ME MAKE A NEW POST SORRY GUYS, I AM USING B16 ARP BOLTS ON MY B20BVTEC WILL THEY BE FINE? I ALREADY HAVE THEM SO CHECKING IF THEY WOULD WORK
Old May 13, 2017 | 08:20 PM
Robert Vasquez's Avatar
im having the same issue, i have stock jdm b20b on a 99 ls automatic integra, fuel pressure is around 30 on idle and 40-42 when accelerating, also the fuel consumption is abnormal less than 15 mpg, is it normal? I have everything from the original engine b18 . P75 intake, obd 2 ecu, but the car fuel efficiency is definitely abnormal, any ideas guys?
Old Apr 26, 2021 | 08:03 PM
Manuel Tobias's Avatar
[QUOTE=Robert Vasquez;51282436]im having the same issue, i have stock jdm b20b on a 99 ls automatic integra, fuel pressure is around 30 on idle and 40-42 when accelerating, also the fuel consumption is abnormal less than 15 mpg, is it normal? I have everything from the original engine b18 . P75 intake, obd 2 ecu, but the car fuel efficiency is definitely abnormal, any ideas guys?[/QUOTE
did u ever fix your problem I have the same problem same issue everything b20b
wasdayuca
Jan 12, 2005 08:36 AM
nsxxtreme
Honda S2000
Mar 15, 2002 05:01 PM
