Alarm, power locks, and remote start question?
First off I have a 95 s. It came with no power locks. I am planning to swap out the engine among other things. What is the best alarm, and aftermarktet power lock kit? If I get a remote starter ( I live in cold nebraska), would it effect any other mode to my computer or anything else? thanks
^ what he said about the starter.
Try here -> https://honda-tech.com/zeroforum?id=27
1. Why would it be a bad idea to leave it in neutral? I leave mine in neutral all the time. I mean unless you live in a hilly area...I don see the problem...
2. U don't have to disable the clutch safety switch, but instead Diode Isolate the ground part of the switch...then you hook up the ground to a ground that the alarm grounds to start the car...
I have remote start in my 5sp, and it works great...
Josh
Josh
^ what he said is a great idea. I m bout to install mine too, i was gonna disable the clutch, but now that i kno this, i ll do that, i never leave my car in gear. i live in orlando Fl, plus, the few times i tried to get into the habit of leavin my car in gear, i stalled very hard cause i m used to let go of the clutch after i start to car, to check my instruments and music....
