Im lost. Need your opinion. Detonation.
Old Oct 1, 2003 | 05:02 PM
BoostedD15B7's Avatar
Default Im lost. Need your opinion. Detonation.
The car is a del sol with a d15b7 turbo 8psi frontmount
Heres the deal....I blew a head gasket this past weekend. Replaced it, all my timing marks are lined up, cam gear is set at zero, stock cam, and i set the timing to 14 degrees. Im running 93 octaine, with 1/2 degree retard per pound of boost, at only 8psi and i heard what i believe was a little detonation in first, at about 5,000 rpm. So i let off real quick and i could see in my review that it puffed out a decent cloud of smoke. Not sure on the color, it was hard to tell. The weird thing is i was running the same timing (14degrees) previously with less boost retard and had no problems. What should i do....Im scared to get on it. Could it be bad plugs? Beats me because i ran with those setting forever with no problem. Maybe i need to reset ecu?
Old Oct 1, 2003 | 05:27 PM
drvfast's Avatar
Default Re: Im lost. Need your opinion. Detonation. (BoostedD15B7)
what are your spark plugs gapped at?
Old Oct 2, 2003 | 03:23 AM
Default Re: Im lost. Need your opinion. Detonation. (drvfast)
running a .030 gap
Old Oct 2, 2003 | 03:30 AM
rjardy's Avatar
warped head/deck surface?
How bad was the headgasket?
Rob
Old Oct 2, 2003 | 03:35 AM
ImAcracker's Avatar
Loved
Cheap head gasket and it is getting hot spots maybe?
Old Oct 2, 2003 | 05:11 AM
Gravy's Avatar
Default Re: Im lost. Need your opinion. Detonation. (ImAcracker)
retard the timing to a full degree per lbs of boost.
Old Oct 3, 2003 | 03:10 AM
Default Re: Im lost. Need your opinion. Detonation. (Gravy)
The gasket wasnt bad at all...I could even see where it was blown. I didnt let it get real hot so im sure its not warped. Once i saw it creeping up like a line or two i shut it off, so it didnt get real hot.
Would i need that much retard at 8psi?
TachiKun
Mar 28, 2016 11:28 AM
drmix
May 27, 2008 09:25 PM
Cyphear
Nov 22, 2004 03:12 AM
donnjuan2point2
Mar 11, 2004 01:59 PM
J T*
Jul 2, 2002 04:27 PM
