Where in the hell does this O-ring go?...ZC head...
Old Oct 1, 2003 | 04:26 PM
*Boostwerks*'s Avatar
Default Where in the hell does this O-ring go?...ZC head...
I pulled the head off the block, set it on my table, and suddenly I had a O-ring about the diameter of the Oil-control jet sitting next to it.
Does the oil-control jet have an external O ring?
Anywhere else this could go? I am 99% sure it came from the head.
Thanks
Bryson
Old Oct 1, 2003 | 05:35 PM
sporkcrx's Avatar
Default Re: Where in the hell does this O-ring go?...ZC head... (Bryson)
There's one small o-ring that goes on the oil control jet...check to see if it's missing. There's a groove (if I can remember right) on the oil control jet where it should go. (assuming the a6 head is similar)
Old Oct 1, 2003 | 07:29 PM
Are you talking about the O-ring that goes around the control-jet and seals it into the block?
or is there another O-ring that is Visible when you take the head off?
The oil control jet has not been removed.
Old Oct 2, 2003 | 08:31 AM
bump
Old Oct 2, 2003 | 11:32 AM
sporkcrx's Avatar
Default Re: (Bryson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">Are you talking about the O-ring that goes around the control-jet and seals it into the block?
The oil control jet has not been removed.</TD></TR></TABLE>
Yea, that's the one I'm talking about. I don't see where another o-ring would come from in the head.
Lamchop0000
Nov 2, 2012 02:34 AM
h22bluelude
Jan 3, 2011 09:06 AM
Chrys007
Jun 26, 2007 01:50 PM
coolusername
Sep 16, 2003 12:03 PM
