If my timing if off will my EGT tell me?
Old Oct 1, 2003 | 01:53 PM
Sinner's Avatar
Default If my timing if off will my EGT tell me?
I have an EGT and wideband. I want to know when I get into the boost around 7 psi will my egt go up if my timing is off? What will tell me that my timing is not retarted enough at higher boost?
Nick
Old Oct 1, 2003 | 02:08 PM
R6Elmo's Avatar
Default Re: If my timing if off will my EGT tell me? (Sinner)
I really don't knwo too much, but i'll give you my two cents. If the egt gets too hot, it could be from running too lean or the timing is too advanced. If too cool, then it's too rich and too retarted.
Danny
Old Oct 1, 2003 | 04:07 PM
Sinner's Avatar
Default Re: If my timing if off will my EGT tell me? (R6Elmo)
anyone else?
Old Oct 1, 2003 | 04:11 PM
Arturbo's Avatar
Better than steak
25 Year Member
Not really. Even 1 deg. of timing can affect temp. as much as 100deg.
art
EFIGUY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R6Elmo &raquo;</TD></TR><TR><TD CLASS="quote">I really don't knwo too much, but i'll give you my two cents. If the egt gets too hot, it could be from running too lean or the timing is too advanced. If too cool, then it's too rich and too retarted.
Danny</TD></TR></TABLE>
Not really Danny,
When the timing is advanced the burn starts sooner in the cycle and has more time to transfer heat to the combustion chamber, water jackets, etc............when it is too late, the heat goes right out the exhasut and makes the EGT's look really high!
Of course fuel mixtures has some effect on this too, but not nearly as much as ignition timing.
Old Oct 1, 2003 | 04:21 PM
turbo Si's Avatar
Default Re: If my timing if off will my EGT tell me? (EFIGUY)
That's true. If your timing is retarded too much, then your temps will skyrocket!
spoolingb20
Apr 26, 2006 10:46 AM
Btothe3rdDegree
Nov 12, 2004 04:53 PM
aron0903
Aug 4, 2004 12:34 AM
X2BOARD
10
Apr 8, 2004 05:18 AM
wzcb08
May 19, 2003 07:47 PM
