Catalytic Converter Question
Old Oct 1, 2003 | 11:17 AM
youngvedder's Avatar
Default Catalytic Converter Question
Should I be looking at getting a high flow cat with my current set up? if so, would I experience gains ?
Cheers,
YV
Old Oct 1, 2003 | 11:25 AM
acuradriva's Avatar
Default Re: Catalytic Converter Question (youngvedder)
that and an exhaust would be the 2 next things i would get. Carsound cats are the best.
Old Oct 1, 2003 | 01:08 PM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Default Re: Catalytic Converter Question (acuradriva)
You won't really see gains with a high flow cat.
BUT, you will see that you need to buy a new one every 3-4 months.
Old Oct 1, 2003 | 01:11 PM
MikeTV
Guest
Posts: n/a
Default Re: Catalytic Converter Question (integra707)
Yes you will see gains, as far as gains go for bolt-ons.....but uh..get yourself a better exhaust first there buddy
Old Oct 1, 2003 | 01:12 PM
dip-set's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra707 &raquo;</TD></TR><TR><TD CLASS="quote">You won't really see gains with a high flow cat.
BUT, you will see that you need to buy a new one every 3-4 months. </TD></TR></TABLE>
why is that...
Old Oct 1, 2003 | 01:44 PM
es four's Avatar
Default Re: Catalytic Converter Question (teg-your-it)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg-your-it &raquo;</TD></TR><TR><TD CLASS="quote">
why is that...</TD></TR></TABLE>
When I had a carsound, I went through 3 in about 9 months.
Then I decided to go back to OEM.
I think other people have had similar experiences as well.
Old Oct 1, 2003 | 02:48 PM
BlueTeg's Avatar
I think other people have had similar experiences as well.</TD></TR></TABLE>
had my SMSP/Carsound for well over a year with no problems. My brother has had his on his car for much longer. No probs at all. I know tons of other people that have run the Carsound cats with no complaints.
The reason the cats will fail is not because of bad craftsmanship....but rather from bad fuel tuning. (the owner's fault....not Carsound)
The following is a quote from a Magnaflow employee who responded to Dave's (SMSP) inquiry on their cat failure:
Originally posted by SMSP in Jun/2002
re: Cat Failure
This post is meant to be a general statement regarding Carsound cats. The following is the response I got from a Magnaflow employee concerning some question I had about the mat that surrounds the catalyst/brick. Magnaflow is a company that is part of the Car Sound Exhaust System company.
"With regard to the mat-it is designed to cushion the ceramic substrate, and is completely functional in that respect. The mat is not required to come to the edge of the substrate in order to cushion the substrate. Of possible cause for substrate failure in which the mat deteriorates is what we refer to as Thermal Failure. At excessively high temperatures, caused by rich fuel mixtures which are not completely burned in the combustion chamber and ignite in the catalytic converter, the stainless steel case expands to the point where the mat is separated from the the case. As exhaust always follows the path of least resistance, the exhaust begins to flow between the mat and the case instead of through the substrate itself. At this point the mat is exposed to exhaust flow and begins to deteriorate. After a period of time, the mat disintegrates and the substrate, which is a brittle ceramic, comes in contact with the steel case and breaks up. So in some cases, the mat disappears because of an excessive heat factor instigated by unburned fuel due to a rich fuel mixture."
The problem lies with you (or your tuner's) ability to dial in the correct a/f ratios on your engine.
Old Oct 1, 2003 | 02:49 PM
BlueTeg's Avatar
Here are some flow rates for oem and aftermarket cats:
Stock NSX 242.1 cfm
Stock Type R 223.6 cfm
Stock Integra 218.3 cfm
Catco (metal core) 2.25" 223.8 cfm
Random Tech 2.25" 297.1 cfm
Catco (std. core) 2.25" 338.2 cfm
Car Sound 2.25" 342.7 cfm
Test Pipe 2.25" 407.1 cfm
cfm = flow capacity in cubic feet per minute
Flow test conducted at Comptech USA.
The numbers speak for themselves, you can decide from here.
If you look at the setups of the guys on here that make "good" power N/A, none of them use the oem cat. Its piping is too small and the catalyst brick is too restrictive.
Old Oct 1, 2003 | 03:25 PM
NightRiderS2K's Avatar
In-N-Out Burger
Default Re: Catalytic Converter Question (BlueTeg)
Just get a Carsound in conjuction with a new upgraded exhaust setup. If you are getting it installed by a mechanic, you will save money...if you will be doing it yourself, then it will save you time and you can do both in just hours.
Carsound
Testpipe
NRG
Old Oct 1, 2003 | 03:35 PM
BlueTeg's Avatar
Default Re: Catalytic Converter Question (NightRider-gsR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NightRider-gsR &raquo;</TD></TR><TR><TD CLASS="quote">
Carsound
Testpipe
agrees with him.
Carsound cat vs. Testpipe dyno.......no difference in power output.
http://mods.team-integra.net/i...t.jpg
Old Oct 1, 2003 | 03:37 PM
cool guys...forgot to list that I had a Tanabe Exhaust.
I'll go and grab one. sounds like a good idea.
thanks again,
YV
Old Oct 1, 2003 | 04:11 PM
b20_ed's Avatar
damn, another lesson learned I C....
Carsound it is!
Old Oct 1, 2003 | 05:58 PM
patdemps's Avatar
Default Re: Catalytic Converter Question (b20_EK)
Carsound, been running it for awhile with not one complaint.
EG5Boy
31
May 20, 2021 03:03 AM
NYStyle
Jul 20, 2005 11:39 AM
B18C-VTI_R
Sep 25, 2004 11:31 AM
teg969
Aug 31, 2004 06:04 PM
itr 00 0108
Feb 24, 2004 06:00 PM
