JDM 4-1 typeR headers in a 91LS
Old Oct 1, 2003 | 11:01 AM
msTEGGY's Avatar
Default JDM 4-1 typeR headers in a 91LS
just what the topic says. will the JDM 4-1 tpyeR header fit on my b18a. what all needs to be modified in order to be installed properly, eventually i will be swapping to B16 or B20 so i shouldn't have problems swapping these headers into those engines.
Old Oct 1, 2003 | 11:09 AM
thaiphob's Avatar
Nikon!!!
Default Re: JDM 4-1 typeR headers in a 91LS (msTEGGY)
it should fit fine but it will hang a li low. so that means your car better not be slammed or your gonna go *ouch* when you bottom out.
Old Oct 1, 2003 | 11:25 AM
Cone's Avatar
Default Re: JDM 4-1 typeR headers in a 91LS (thaiphob)
just what he said. Everything should bolt up just fine, it will hang a little low, but if you get the OEM Honda Type R manifold, you can get a skid plate (www.heeltoeauto.com). Also, if you get the OEM manifold, also remember to grind away the internal welds and re weld it on the outside.
-Andrew
Old Oct 1, 2003 | 12:59 PM
dustrag's Avatar
on your header your going to have a 2 1/2" collector and i am pretty sure that you either need to make a test pipe or modify yout cat
Old Oct 1, 2003 | 01:26 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: (dustrag)
JDM 4-1 header + NYC potholes= dented header. The header hangs kinda low on these cars. I ended up getting the Apexi header afterwards.
Old Oct 1, 2003 | 04:00 PM
msTEGGY's Avatar
Default Re: (FrostyDC4)
damn if this is the case then Winnipeg potholes will dent it nice. thanks guy!
Old Oct 1, 2003 | 05:22 PM
jeebusm3's Avatar
mine barely hangs lower than stock on my GSR. The DC JDM 4-1 is lower though. I got a skidplate just in case but I've yet to scrape it.
Old Oct 2, 2003 | 07:47 AM
MAV3RiCK478's Avatar
Default Re: (gtravsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gtravsr &raquo;</TD></TR><TR><TD CLASS="quote">mine barely hangs lower than stock on my GSR. The DC JDM 4-1 is lower though. I got a skidplate just in case but I've yet to scrape it.</TD></TR></TABLE>
he's asking about the DA chassis not the DC chassis.
don't you have to alter your crossmember to use the ITR header in a DA?
Old Oct 2, 2003 | 02:20 PM
msTEGGY's Avatar
yes the crossmember needs to be modified
Old Oct 3, 2003 | 11:01 AM
Cone's Avatar
Default Re: (msTEGGY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msTEGGY &raquo;</TD></TR><TR><TD CLASS="quote">yes the crossmember needs to be modified</TD></TR></TABLE>
that sucks...what needs to be done?
Old Oct 3, 2003 | 02:14 PM
VNTEC's Avatar
B A N N E D
Default Re: (Stealth 95 GS-R)
It needs to be cut slightly to clear, nothing much. The piping also needs to be extended and turned around 180 degrees cuz the flange is opposite of eachother
Old Oct 3, 2003 | 02:38 PM
Try2Live4God's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FrostyDC4 &raquo;</TD></TR><TR><TD CLASS="quote">JDM 4-1 header + NYC potholes= dented header. The header hangs kinda low on these cars. I ended up getting the Apexi header afterwards.</TD></TR></TABLE>
I feel you on that...I live in NYC...and I already dented my headers! Gettin' ready to put another one on though..
92-CivicLX
May 7, 2011 07:38 AM
HONDRETTI
Nov 6, 2007 06:34 PM
Sukii
Feb 28, 2005 09:10 PM
JuicyJDM
Jun 19, 2004 06:33 AM
JSpecwest
Oct 11, 2001 02:56 PM
