ecu and tranny questions for ls vtec setup???
i did a quick search and couldnt find anything so please dont flame... i have a 98 auto ls and im looking into buying a complete b16a swap motor tranny ecu... my question is will this work ..... i want to use the head tranny and ecu but im not sure if the ecu will work? if not what one(s) will? here is the complete swap and price is this a good deal or is there a cheaper route??? B16A 88-91 (SiR I) Motor, Tranny, Computer
Price: $ 1250.00 Plus shipping and handling.
Availability: In stock and ready to go
- Motor
- Cable Tranny (Y1, S1, J1)
- ECU (PR3, PW0)
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
- LSD Tranny (Optional +$300)
any info that you might have will be greatly appriciated.... once again i did a quick search and i know that you have talked about this thousands of times but flaming is really not necessary... t.i.a
- Motor
- ECU (PR3, PW0)
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
the entire IM will not work (sensors and stuff, the hunk of metal will be ok) Since your car is auto anyway, and anything you do to add a standard tranny will be custom fab'ed, you might be better off with a cable tranny. You're linkage will not work, and neither will either of the ECU's you have right now.
there are a lot of cheaper route that will work sir 2 might be better i has more power try looking on ebay for the motor use just the engine there r even some store put u will need the ecu for the engine u get and u will also or probably have to do obd 2 to 1 harness to connect edu . u can always buy a none modified ecu the p28 or p30 are the most common and are entirely reprogrammable and the most supported .the harness on ebay is 89 or less and on hondatech there a site call http :// http://www.jdmshit.com check it out just a thought
i about to lv/vtec with an auto to and use a vafc i not doing the stick tranny swap right now where r u getting the engine from
im gettin the engine from http://www.hmotorsonline.com a friend of mine just got his b-20 from them it was a decent price aswell as product... as for the other post... im using only the head, tranny, clutch, flywheel, and ecu from the parts listed above the rest im selling on ebay i just wanted to know if the ecu would work? i was informed that any b series vtec ecu manual tranny would work! so thats my question..... can anyone help me with that? ... t.i.a
any vtec ecu will work but if your going that route u should get a p28 or p30 most responsive vtec ecu and most commonly reprogrammed as well u can have knock sensor remove common problem for ls/vtec manual swap if u don't remove from p28 or p30 cannot be modified on odb 2 2 complex
thanks for the info...... do you know where i can get the p28 or p30 from and about how much does it cost??? once again i am new to all this so any help on topic or off will help.... t.i.a
i can help you w/ the chipped p28 ecu........ very reputable if you click on my reference thread in my signature......... PM me if you have any questions regarding the ecu.
thanks
-Jay-
thanks
-Jay-
