Tried to fit the 11.4" rotors to ITR...
The rotors fit fine and the bracket lined up the caliper well, but...the stock ITR caliper is too tall and the pads have too much overhang. The good news is that if you wanted to use the 11.4" rotors all you need to do is get a pair of regular Integra rear calipers, and it will bolt on.....
what exactly did you do brian? fitting 11.4" rear rotors on a non ITR? please explain to us again.
[Modified by yeah LS, 9:50 AM 8/27/2001]
You wouldn't want to do this because the regular Integra rear pads are smaller than ITR one's.
not to say Fastbrakes produces crap kits either.... Ok....I'm lost too.....!
fyi smaller pad area isnt going to make that much of a difference. i believe the piston size is larger on the ITR caliper than the non ITR caliper tho. that DOES make a difference. pad area usually means pad life. if you have a huge pad, itll just last longer than a small pad braking at the same diameter (affective diameter that is!)
anyway brian...still waiting for more info so that we are not lost.
emaka9
Nov 21, 2008 09:57 AM
Solscud007
Dec 8, 2004 10:00 PM
