I'm done!!! Thank you GroundZero Motorsports. Can we say 400 Club! Dyno inside!
Old Sep 30, 2003 | 09:43 PM
BodyKits NW's Avatar
Default I'm done!!! Thank you GroundZero Motorsports. Can we say 400 Club! Dyno inside!
Well guys I finally got my car done and tuned. I was going to have Crescent tune the car, but he's just too far. The car was running way rich and was fouling plugs just at idle. Didn't wanna risk hurting my new engine. GroundZero who I have known for years came highly recommended and they are only 15 minutes away. I didn't know they offered tuning till not too long ago. Well Kenny and the GZ crew hooked me up and tuned the car awesome! Fantastic power, and great customer service. He told me step by step what he was doing and really did a outstanding job on tuning my car.
With only 15-20 miles on the engine we did this! Since I have not gotten my boost controller this was running off the Tial Wastegate Spring which held about 10.5lbs of boost steady. So I am not sure what to say 10 or 11lbs, but anyways they still made some awesome numbers and this is with my 3" High Flow cat installed. Who knows how clogged that sucker is from how rich it was. Also this was on a mustang dyno so if you add about 15 percent onto this run your looking at about 391whp. Just look at the graph, this explains it all.
Ohh yah for all those people that complain about the Max-Rev BOV, the damn thing is awesome!!!! With a little tweaking it sounds Bad-***!
This was all done on 91 Octane Pump Gas. Not sure if the tuning is conservative, but it runs great!!! I think there is more power to be had, especially with that High Flow cat out of the way. But we'll leave that to Ground Zero to answer that question. Also this was done with only 2.5 hours of tuning!!!! No Check Engine Lights, and great idle.
-Lots of time, patience, and the right combo of parts. Took me awhile to put together, but it paid off! Worked my *** off!
Check out that Air Fuel!
RED=Engine RPM
Yellow=Boost Pressure "Steady as you can see"
Fuel Pressure=Purple Line going STRAIGHT LEFT TO RIGHT. "Steady as well"
Thanks Full-Race, Import Builders, Joe Alaniz, Crescent, Earl, Viren, Arturbo and everyone that has helped with my setup.
Engine:
B18c5 2.0 Liter 9:1 Compression
Eagle Rods
880cc Injectors
SC61 with a Full-Race Manifold
PWR Intercooler
3" Exhaust with High Flow Car
2.5 Intercooler Piping
Tial 40mm Wastegate
Max-Rev BOV
Modified by BodyKits NW at 10:54 PM 9/30/2003
Old Sep 30, 2003 | 09:50 PM
Ri5e's Avatar
Default Re: I'm done!!! Thank you GroundZero Motorsports. Can we say 400 Club! Dyno inside! (BodyKits NW)
400 whp with 10-11 psi?
Old Sep 30, 2003 | 09:57 PM
PureTeg420's Avatar
Default Re: I'm done!!! Thank you GroundZero Motorsports. Can we say 400 Club! Dyno inside! (Tein Man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tein Man &raquo;</TD></TR><TR><TD CLASS="quote">400 whp with 10-11 psi?</TD></TR></TABLE>
I see 340whp..not 400whp. But anyways looks good...I had kenny chip my hondata a while ago...definatly a good guy
Old Sep 30, 2003 | 10:00 PM
TurboRBoostedS2G's Avatar
Default Re: I'm done!!! Thank you GroundZero Motorsports. Can we say 400 Club! Dyno inside! (PureTeg420)
going to have to agree 340 is a bit shy of 400 but still nice numbers to a fellow B18C5 boosted
Old Sep 30, 2003 | 10:02 PM
Tofurky's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PureTeg420 &raquo;</TD></TR><TR><TD CLASS="quote">
I see 340whp..not 400whp. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BodyKits NW &raquo;</TD></TR><TR><TD CLASS="quote">Also this was on a mustang dyno so if you add about 15 percent onto this run your looking at about 391whp. Just look at the graph, this explains it all.</TD></TR></TABLE>
very nice
Old Sep 30, 2003 | 10:03 PM
Default Re: I'm done!!! Thank you GroundZero Motorsports. Can we say 400 Club! Dyno inside! (TurboRBoostedS2
Mustang Dyno guys!!!! Most of you are used to seeing DynoJet Dyno Sheets. There is a 15 percent difference in power.
Ri5e's Avatar
he did it on a mustang dyno. i'd like to see some more dynos
Old Sep 30, 2003 | 10:07 PM
earl's Avatar
Old Sep 30, 2003 | 10:37 PM
TurboDANDEE's Avatar
very nice man, got any pics of the car? now take it to the track!
Old Sep 30, 2003 | 10:42 PM
Arturbo's Avatar
Better than steak
25 Year Member
Good #'s on a good dyno.
Old Sep 30, 2003 | 11:06 PM
5thgencivic's Avatar
I was wondering how good groundzero tuned. If I go the hondata route that is where I will go.. Sweet numbers
Old Sep 30, 2003 | 11:08 PM
PrecisionH23a's Avatar
You are 9whp shy of being in our club! But... we'll let you slide in... congrats
Old Sep 30, 2003 | 11:12 PM
hehe you just wait till I remove this damn CAT
BTW The Precision SC61 is not with the S Trim. If you look at the 2nd graph you can see the yellow line which monitors boost. You can see that Full Boost is acheived at about 4950-5000k!!
Turbo Specs-SC61 compressor is a 61mm GT40 56 trim in a T04E(60AR) compressor housing. The turbine is a T3 .63AR with a T04 69 Trim turbine wheel.
Old Sep 30, 2003 | 11:14 PM
Full-Race Javier's Avatar
good job more pics of the car
Old Sep 30, 2003 | 11:24 PM
Boostfed's Avatar
New User
Big Props! Nice #s for LOW boost now go get your EBC and turn it up!
Arturbo's Avatar
Better than steak
25 Year Member
Turbo Specs-SC61 compressor is a 61mm GT40 56 trim in a T04E(60AR) compressor housing. The turbine is a T3 .63AR with a T04 69 Trim turbine wheel.</TD></TR></TABLE>
Thats some good info.
Old Sep 30, 2003 | 11:34 PM
HotRodTeg's Avatar
nice numbers andy i was imprested with your setup.
new fuel pump and a boost controller and get that CAT out of there.
Lets turn up the BOOST.
Old Oct 1, 2003 | 12:25 AM
Full-Race Geoff's Avatar
Old Oct 1, 2003 | 12:28 AM
swlabhot's Avatar
400whp within grasp at only 10-11psi.... I guess u got a very good combo of parts. What management u using?
Old Oct 1, 2003 | 01:30 AM
Unsung's Avatar
Nice numbers! Is this daily Andy?
Old Oct 1, 2003 | 03:48 AM
Default Re: I'm done!!! Thank you GroundZero Motorsports. Can we say 400 Club! Dyno inside! (Unsung EM1)
Hondata!! Idles and drives like stock! Kenny has got some unfinished business with the car I really wanna know how big of a difference there will be if I free up my exhaust a little more. If I am right, you gotta covert the Torque Power rating as well. I should be about 260lbs of torque to the wheels.
"Unsung EM1" Yup Daily on 91 Octane.
Old Oct 1, 2003 | 04:35 AM
swlabhot's Avatar
Your ECU is OBDII correct?? So are you using a OBDII - OBDI conversion harness and a OBDI ecu?? What else do you need to use Hondata on OBDII ecus?
I'm planning to go this route as well as I've got 98' ITR and I'm trying to decide between this or Apexi PFC
Old Oct 1, 2003 | 04:36 AM
symba's Avatar
Good numbers. I'm jealous. Just sent you a PM
Old Oct 1, 2003 | 04:52 AM
Default Re: I'm done!!! Thank you GroundZero Motorsports. Can we say 400 Club! Dyno inside! (symba)
Hondata man, forget the Apexi lol. Yah I have a OBD 2 car, but I run a OBD 1 Ecu. P28 to be exact.
Old Oct 1, 2003 | 05:26 AM
Gravy's Avatar
nice numbers and setup. thats it im going 2.0!!
