2000 front bumper on 95 ls.
Old Sep 30, 2003 | 07:32 PM
ggangtong81's Avatar
Default 2000 front bumper on 95 ls.
well, the previous owner did that conversion, but the hood, fender, and front bumper don't fit to each other. any suggestion??
Old Sep 30, 2003 | 07:37 PM
quikB18B's Avatar
Default Re: 2000 front bumper on 95 ls. (ggangtong81)
Car must have been in an accident if it isn't lining up. It's a direct bolt on without any modifications
Old Sep 30, 2003 | 07:40 PM
Default Re: 2000 front bumper on 95 ls. (quikB18B)
should i mold the gaps?? it's not huge, but still...
Old Sep 30, 2003 | 07:58 PM
thaiphob's Avatar
Nikon!!!
dont mold them. just try to alighn it yourself.
Old Sep 30, 2003 | 10:04 PM
powerslide360's Avatar
make sure you have the matching 2000 pieces -- hood, front bumper, lights, fenders -- I wouldnt mix and match -- if you do the newer conversion, make sure all the pieces are either 94-97 -OR- 98-2001!
Old Oct 1, 2003 | 03:53 AM
JimBlake's Avatar
Default Re: 2000 front bumper on 95 ls. (powerslide360)
I thought the hood & fenders didn't change. Only the headlights & bumper skin.
If the hood & fenders don't line up, something's bent.
Old Oct 1, 2003 | 04:51 AM
Default Re: 2000 front bumper on 95 ls. (JimBlake)
how can i align it?
Old Oct 1, 2003 | 05:38 AM
JimBlake's Avatar
Take it off.
The structural bumper is bolted on, I don't think there's much room for movement on that part. That can get bent in a collision, & you can't straighten it by hand. Check the styrofoam block that sits in the bumper - is it mashed? Same for those smaller plastic blocks in each end.
There's a steel bracket in each end of the bumper skin, where it sits against the front of each fender. Maybe those are bent or rusted?
Loosely assemble that steel strip across the top with all those screws. Then wiggle the bumper around, straightening it & pushing it into position, while you tighten them all. You need about 6 arms to do this properly. That's why lots of body shops never get it right - one guy always thinks he can do it by himself...
If the hood doesn't line up with the fenders; well that kinda says it all, right?
Miss_Beccaxo
Paint and Body
Dec 16, 2012 09:03 AM
hafaadaiteg
Sep 6, 2007 08:39 AM
tEhNgUyeN
10
May 20, 2005 04:19 AM
WHiTETYPEs
Feb 9, 2005 03:12 PM
Got Utensils
Apr 28, 2004 08:46 PM
